[snappyHexMesh] Error analysis: "ended prematurely and may have crashed. exit code 22" |
August 22, 2015, 14:44 |
john mcgeorge
Rep Power: 11 |
When I run snappyHexMesh I get error snappyHexMesh ended prematurely and may have crashed.exit code 22.Get same error in log.simpleFoam.Why does this happen
August 22, 2015, 16:27 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings John,
Are you sure the error code isn't "42"? Can you provide more details? Please follow the instructions given here: http://www.cfd-online.com/Forums/ope...-get-help.html Furthermore, are you able to run the first tutorial on the OpenFOAM User Guide or do you get the same error message? Best regards, Bruno
August 22, 2015, 16:49 |
Error 22
john mcgeorge
Rep Power: 11 |
No getting error 22.Also when I open ParaView my model sits across not inline with wind tunnel and is not centred.
August 22, 2015, 18:22 |
Bruno Santos
Rep Power: 128 |
If you don't provide more details for diagnosing the problem, then it's not possible to help you.
The error code "22" is too generic and does not relate to any specific meaning. |
August 22, 2015, 19:05 |
Error
john mcgeorge
Rep Power: 11 |
Thanks for reply.I am trying to use motorBike tutorial to check body oF my racing car.Created shape in Rhino cad.Do I need to mesh before going into OP or will OP do that using blockmesh and snappyhexmesh.Also my object is small compaired to wind tunnel and is the wrong position and facing across not with flow.I am new to this but need sum pointers and will work out frm there.I do not have internet but send frm cellphone.Cannot transfer fileS into forum.Any help is welcome.
August 23, 2015, 12:48 |
Bruno Santos
Rep Power: 128 |
Quick answer:
August 23, 2015, 14:04 |
Error
john mcgeorge
Rep Power: 11 |
Thanks for reply.I am using OpenFOAM 15.06 on Windows.When I ran motorBike tutorial it gave same error.So fault is in snappyHexMesh.I cannot use OpenFOAM in Ubuntu as without internet which I do not have I cannot download updates online.
August 23, 2015, 14:24 |
Bruno Santos
Rep Power: 128 |
Then that's beyond me. You are using a unofficial port of OpenFOAM for Windows, maintained by a company named CFDsupport, who didn't even bother giving their port a proper name, so that it wouldn't be confused with the official versions of OpenFOAM that are provided by the OpenFOAM Foundation.
Anyway, you will have to contact them and request them to fix your problem. |
August 23, 2015, 16:40 |
Error
#9 |
john mcgeorge
Rep Power: 11 |
Sorry did not know though all the same people.Anyhow how do I get my model in centre of wind tunnel in motorBike tutorial.Is it done in paraView or in one of the files.Thanks Again.
August 23, 2015, 17:03 |
#10 |
Bruno Santos
Rep Power: 128 |
Ah, right, sorry, forgot about that question.
You have 4 possibilities:
August 23, 2015, 17:18 |
SnappyHexMesh
#11 |
john mcgeorge
Rep Power: 11 |
So u saying rather move tunnel than model.I am there now so alter vertices.It will not affect anything will it.I cannot mesh my model with either blockMesh or snappyHexMesh.Thanks
error analysis, snappyhexmesh 3d |
