[Other] Cannot find patchField entry for walls
Old   June 8, 2015, 23:57
Default Cannot find patchField entry for walls
eruwaedhiel is on a distinguished road
Hello! In my quest to alter the propeller pimpleDyMFoam tutorial to become a helicopter with rotating rotors, I've decided to alter each .obj file a step at a time to figure out why my mesh creations aren't working (I have another thread asking in particular why I can't see my results from snappyHexMesh in paraFoam). Since I am extremely new to OpenFoam (only been using it about 2 weeks now), I have some questions and a bug I'm seeing that I hope some of you more experienced people can help me with:
- Where does the mesh generated from blockMesh go in the vanilla propeller tutorial? It seems to not exist, as the largest mesh is outerCylinder.
- If I change the scaling in the blockMeshDict (in either direction - I've tried multiplying the vertices by 0.1, 10, 100, etc.), I get a "Cannot find patchField entry for walls" error in snappyHexMesh.
- If I try to use my alternate, helicopter-sized outerCylinder .obj file (attached if anyone is interested in trying this), snappyHexMesh completes successfully but paraFoam crashes and gives me a "Cannot find patchField entry for walls" error.
I'm a little confused as to where these errors are coming from, mostly because I don't exactly understand how blockMesh and snappyHexMesh interact. Any help would be appreciated, thanks!
eruwaedhiel is offline   Reply With Quote
mesh, pimpledymfoam, propeller
Cannot find patchField entry for InletWall range_rover OpenFOAM Running, Solving & CFD 5 November 18, 2020 22:21
Parallel snappyHexMesh problem: Cannot find patchField entry for procBoundary2to7 hconel OpenFOAM Pre-Processing 0 October 5, 2018 18:22
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 13:38
Problem Building OF on Centos cluster (no admin rights) CKH OpenFOAM Installation 5 November 13, 2011 07:32
Converting Starccm+ mesh Ladnam OpenFOAM 0 September 14, 2011 07:30
