[Commercial meshers] foamMeshToFluent - very high skewness after conversion! |
January 18, 2015, 16:13 |
Kumar
Rep Power: 13 |
Dear FOAMers,
I am writing this post to get your expert opinion on the issue of skewness after mesh conversion that has been troubling for some time now. I have meshed a relatively simple geometry with snappyHexMesh. CheckMesh reveals all quality parameters to be OK, with max. face skewness reported about 2. The case runs smoothly with first order schemes and I know that meshes with skewness up to 4 can be safely run with OpenFOAM. When I convert the mesh using foamMeshToFluent and check the mesh in Fluent, it says there are many cells with equiangle skew more than 0.98. By this metric, the mesh is really bad. However, the case runs in Fluent as well. I am aware that OpenFOAM and Fluent use different metrics for defining skewness - openfoam using a face based one which is a measure of the deviation of the vector connecting the cell centres from the face centroid and fluent, a cell based one for equiangle skew. What I am confused is: After all it is the same mesh with the same points, nodes, faces and cells. By one defenition the mesh is perfectly OK while by the other, it is more or less useless. Can there be so much discordance between the two? Any thoughts are most welcome. I would be happy to share the case if anyone needs. -Kumar |
January 18, 2015, 16:38 |
#2 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer - here's some reading material:
[ANSYS Meshing] Ansys meshing result very high skewness | m5edr | ANSYS Meshing & Geometry | 18 | February 3, 2020 12:35 |
[ANSYS Meshing] Difference between average skewness and maximum skewness | ParasuRam | ANSYS Meshing & Geometry | 4 | February 15, 2018 07:22 |
[ANSYS Meshing] Problem with High Skewness Mesh | CFD2016 | ANSYS Meshing & Geometry | 12 | June 8, 2016 02:28 |
[GAMBIT] tangent edges and high skewness | CaroVandame | ANSYS Meshing & Geometry | 8 | May 7, 2012 10:39 |
Gambit mesh: tangent edges and high skewness | CaroVandame | FLUENT | 2 | May 3, 2012 23:21 |
