[blockMesh] Problem with mesh generation
Old   October 27, 2013, 08:19
Default Problem with mesh generation
Silvia
Silvy is on a distinguished road
Dear all ,
I am very inexperienced in OpenFOAM ,so I apologize if my question is too trivial.
I have a problem with the generation of my mesh. Using blockMeshDict I ​​have created a box with inside a cylinder. I set the boundary conditions (inlet , outlet , simmetry , AMIinside and AMIoutside ) .
By snappyHexMeshDict then I put in the cylinder the stl geometry of a turbine .
But when I run snappyHexMesh in ParaView I can only see one geometry, or the cylinder with the turbine on the inside, or the box without the cylinder inside of it .
I can see only one or the cylinder or box depending on the point I took in locationInMesh. If I take a point out of the cylinder in ParaView I will only see the box without the cylinder. if I take a point inside the cylinder in ParaView I will see only the cylinder with the mesh of the turbine on the inside.
it seems that the two geometries are not linked . But if I build a single geometry so that the box and the cylinder have coincident vertices, I can no longer difinite AMI between the two geometries .
I also took a look at the tutorials as propeller and questions in the forum but I can not find a solution to my problem : connect the two geometries in blockMesh keeping the AMI as a boundary condition between the two .
Below is my file blockMeshDict.
Thank you very much for your help.
| \\ / O peration | Version: 2.1.x |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1;
vertices
(-10 11 -10) //0
(10 11 -10) //1
(10 11 10) //2
(-10 11 10) //3
(-10 -11 -10) //4
(10 -11 -10) //5
(10 -11 10) //6
(-10 -11 10) //7
(-17.6776695296636881100211 11 -17.6776695296636881100211) //8
(17.6776695296636881100211 11 -17.6776695296636881100211) //9
(17.6776695296636881100211 11 17.6776695296636881100211) //10
(-17.6776695296636881100211 11 17.6776695296636881100211) //11
(-17.6776695296636881100211 -11 -17.6776695296636881100211) //12
(17.6776695296636881100211 -11 -17.6776695296636881100211) //13
(17.6776695296636881100211 -11 17.6776695296636881100211) //14
(-17.6776695296636881100211 -11 17.6776695296636881100211) //15
(-17.6776695296636881100211 11 -17.6776695296636881100211) //16
(17.6776695296636881100211 11 -17.6776695296636881100211) //17
(17.6776695296636881100211 11 17.6776695296636881100211) //18
(-17.6776695296636881100211 11 17.6776695296636881100211) //19
(-17.6776695296636881100211 -11 -17.6776695296636881100211) //20
(17.6776695296636881100211 -11 -17.6776695296636881100211) //21
(17.6776695296636881100211 -11 17.6776695296636881100211) //22
(-17.6776695296636881100211 -11 17.6776695296636881100211) //23
(-75 11 -75) //24
(75 11 -75) //25
(75 11 75) //26
(-75 11 75) //27
(-75 -11 -75) //28
(75 -11 -75) //29
(75 -11 75) //30
(-75 -11 75) //31
blocks
hex (0 1 2 3 4 5 6 7) rotor (10 10 10) simpleGrading (1 1 1)
hex (8 9 1 0 12 13 5 4) rotor (10 10 10) simpleGrading (1 1 1)
hex (1 9 10 2 5 13 14 6) rotor (10 10 10) simpleGrading (1 1 1)
hex (10 11 3 2 14 15 7 6) rotor (10 10 10) simpleGrading (1 1 1)
hex (0 3 11 8 4 7 15 12) rotor (10 10 10) simpleGrading (1 1 1)
hex (24 25 17 16 28 29 21 20) Fluid (10 10 10) simpleGrading (1 1 1)
hex (17 25 26 18 21 29 30 22) Fluid (10 10 10) simpleGrading (1 1 1)
hex (26 27 19 18 30 31 23 22) Fluid (10 10 10) simpleGrading (1 1 1)
hex (16 19 27 24 20 23 31 28) Fluid (10 10 10) simpleGrading (1 1 1)
edges
arc 9 10 (-17.6776695296636881100211 11 17.6776695296636881100211)
arc 13 14 (-17.6776695296636881100211 -11 17.6776695296636881100211)
arc 11 8 (17.6776695296636881100211 11 -17.6776695296636881100211)
arc 15 12 (17.6776695296636881100211 -11 -17.6776695296636881100211)
arc 9 8 (-17.6776695296636881100211 11 17.6776695296636881100211)
arc 13 12 (-17.6776695296636881100211 -11 17.6776695296636881100211)
arc 11 10 (17.6776695296636881100211 11 -17.6776695296636881100211)
arc 15 14 (17.6776695296636881100211 -11 -17.6776695296636881100211)
arc 17 18 (-17.6776695296636881100211 11 17.6776695296636881100211)
arc 21 22 (-17.6776695296636881100211 -11 17.6776695296636881100211)
arc 19 16 (17.6776695296636881100211 11 -17.6776695296636881100211)
arc 23 20 (17.6776695296636881100211 -11 -17.6776695296636881100211)
arc 17 16 (-17.6776695296636881100211 11 17.6776695296636881100211)
arc 21 20 (-17.6776695296636881100211 -11 17.6776695296636881100211)
arc 19 18 (17.6776695296636881100211 11 -17.6776695296636881100211)
arc 23 22 (17.6776695296636881100211 -11 -17.6776695296636881100211)
boundary
inlet
type patch;
faces
(27 24 28 31)
outlet
type patch;
faces
(26 25 29 30)
symmetry
type symmetryPlane;
faces
(0 1 2 3)
(1 9 10 2)
(11 10 2 3)
(8 9 1 0)
(0 3 11 8)
(4 5 6 7)
(5 13 14 6)
(15 14 6 7)
(12 13 5 4)
(4 7 15 12)
(17 25 26 18)
(21 29 30 22)
(26 27 19 18)
(30 31 23 22)
(24 25 17 16)
(28 29 21 20)
(16 19 27 24)
(20 23 31 28)
(27 26 30 31)
(24 25 29 28)
AMIinside
type cyclicAMI;
neighbourPatch AMIoutside;
faces
(9 13 14 10)
(11 10 14 15)
(11 8 12 15)
(8 9 13 12)
AMIoutside
type cyclicAMI;
neighbourPatch AMIinside;
faces
(17 21 22 18)
(19 18 22 23)
(19 16 20 23)
(16 17 21 20)
Silvy is offline   Reply With Quote
Old   March 28, 2015, 01:33
Default have you sorted your issue?
Lisandro Maders
Lisandro Maders is on a distinguished road
have you sorted your issue? I am a beginner too, and I have a simple question that I hope you can answer, as I see since 2013 you use OpenFOAM.
I want to see my mesh on ParaView having only the blockMeshDict files as well the files generated by blockMesh command (points, faces, etc..). I do not have at the moment the solution files like fvSchemes, fvSolution, controlDict, etc.
Thanks a lot.
Regards, Lisandro
Lisandro Maders is offline   Reply With Quote
Old   March 28, 2015, 07:33
Alexander Bartel
alexB is on a distinguished road
Hi Lisandro,
you can copy the necessary files from tutorial cases...
Just adapt them for your case afterwards.
regards
Alex
alexB is offline   Reply With Quote
Old   March 31, 2015, 20:29
Lisandro Maders
Originally Posted by alexB View Post
Hi Lisandro,
regards
Alex
Yes but the thing is, I would need to adjust all the patches of the other case files to match ith the patches of my mesh.... If I need to do this everytime I want to create a mesh and verify it, it loses all the sense of creating the mesh and check it in the beginning..
Thanks for your reply..
Lisandro
Old   April 1, 2015, 17:03
Alexander Bartel
you just need the controldict, fvSchemes and fvSolution files for blockmesh.
You don't have to run the solver.
they are without any references to patches in the tutorial cases i saw.
regards Alex
Old   June 10, 2015, 09:59
Gizela
Gizazu is on a distinguished road
Hi. Iḿ new to OpenFoam, and i hope i can find support here with your help.
I´m trying to create a channel with a pier inside of it, I want the pier to be an obstacle. I wrote the blockMeshDict and then when i was running blockmesh, an error returned (see image)
Attached there is the blockMeshDict file.
Help me please, i want to know what i did wrong? or what is missing?
Regards
File Type: jpg Captura de ecrã de 2015-06-10 14:41:38.jpg (50.3 KB, 23 views)
Gizazu is offline   Reply With Quote
Old   June 10, 2015, 18:49
Alexander Bartel
Hi Gizela,
after starring a while at your blockmeshdict, I solved your problem.
You made one error in reasoning... If you want to simulate the flow around an obstacle, you haven't to mesh the obstacle itself.
Just remove your last block and look at your mesh with paraView etc.
You will realize your error.
regards
Alex
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
Old   June 11, 2015, 05:49
Gizela
Hi Gizela,
regards
Alex
Hi Alex,
Thank you, it worked and i already have my channel with a pier.
I have a doubt:
The scope of my thesis is to study the development of the cavity of erosion around the pier.
Now that i have the channel mesh, i want to know what solver can I use to simulate that and how can I represent and consider sediment transportation in OpenFoam?
Is it right to use the pisoFoam solver to study the pressure and velocity around the pier (taking the bed as a dynamic/moving wall - to analyze the bed deformation)?
Regards
Gizela
Old   June 11, 2015, 17:45
Alexander Bartel
Hi Gizela,
I am glad that it was just this little prob with your mesh.
And I must say, that I am not into your other issue.
But one suggestion:
Better post in another subforum (solvers etc. ), there you will get quick better help.
regards
Alex
Old   June 12, 2015, 09:11
Gizela
Thank you Alex.
I´ḿ going to do that.
Regards
Old   July 12, 2015, 05:05
Default propller domain meshing with ansys meshing
  #11
sohrabmajd is on a distinguished road
hi 2 all
I'm new user of ansys that want to use ansys cfx for a ducted propeller.
i can't mesh my model as good as that my solver give me best results.
how can i mesh my model with boundary layers that have fine meshes near propeller and duct and meshes grow slowly linearly with distance from the duct?
I work with ansys workbench and fluid flow(CFX).
thanks
sohrabmajd is offline   Reply With Quote
Old   July 12, 2015, 07:36
Lisandro Maders
regards Alex
I forgot to give you a feedback. I was missing the fv* files.. Once I put them in their respective folders I could see it! Thank you!
Lisandro
Old   July 12, 2015, 17:10
Alexander Bartel
Originally Posted by sohrabmajd View Post
hi 2 all
thanks
wrong subforum you are in the OpenFOAM-subforum... with OpenFOAM I would recommend snappyHexMesh to you.
regards
Alex
[ICEM] Problem making structured mesh on a surface froztbear ANSYS Meshing & Geometry 4 November 10, 2011 09:52
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 09:52
Problem with mesh generation Nestor FLUENT 3 November 1, 2006 03:54
Mesh generation problem Lam FLUENT 2 December 25, 2003 13:37
Latest news in mesh generation Robert Schneiders Main CFD Forum 0 March 2, 1999 05:07
