[mesh manipulation] how should we remove the Concave cells from the mesh?
Like Tree16Likes
Old   March 5, 2020, 17:35
Ali Shayegh
amuzeshi is on a distinguished road
This is the golden comment
Originally Posted by wyldckat View Post
...Without the VTK Polyhedron representation, what happens is that the cells are sliced (decomposed) into hexahedral or tetrahedral shaped cells, so that it's most likely to be properly represented on-screen. ...
In order to mesh a 2D geometry, I used snappyHexMesh and then extrudeMesh. What I obtained was some hex elements (concaveCells, to be specific) that were decomposed into tet elements.
This comment clarified this as a representation issue not a polyMesh problem.
Thanks
amuzeshi is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh sticking point natty_king OpenFOAM Meshing & Mesh Conversion 11 February 20, 2024 10:12
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 05:17
[snappyHexMesh] Snappyhex mesh: poor inlet mesh Swagga5aur OpenFOAM Meshing & Mesh Conversion 1 December 3, 2016 17:59
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 10:03
