May 18, 2007, 13:57 |
Hi all-
As I've tried to co
Doug Hunsaker
Rep Power: 17 |
Hi all-
As I've tried to compile specific applications, a common error continues to emerge: /usr/bin/ld: cannot find The error says it cannot find -lfiniteVolume or -lcfdTools or -lwhatever. I've seen this problem on other posts, but haven't found a remedy to the problem. Does anyone know the root cause of the problem? I'm sure it's a simple fix in the options file of the make folder of the application, but I'm not sure what I'm doing wrong and what I ought to change. And, it seems to be a common problem as I compile many applications. Is there a way to solve the problem for all of the applications at once? Thanks in advance for your help. I'm running on Ubuntu, 32bit. -doug |
May 19, 2007, 00:11 |
Hmmm - ran into this problem y
Richard Morgans
Rep Power: 17 |
Hmmm - ran into this problem yesterday on a students computer...
Havent fixed it yet, but http://translate.google.com/translate?hl=en&sl=it&u=http://mavimo.netsons.org/op enfoam_14_su_ubuntu_704&sa=X&oi=translate&resnum=1 0&ct=result&prev=/search%3Fq%3 Dopenfoam%2Bubuntu%26hl%3Den%26rlz%3D1B3GGGL_enAU2 19AU219%26pwst%3D1 says try sudo apt-get install build-essential I know on 64 bit ubuntu binutils libiberty requires binutils-dev http://ubuntuforums.org/showthread.php?p=2339143 Cheers Rick |
May 19, 2007, 20:29 |
Rick-
Thank you! I found th
Doug Hunsaker
Rep Power: 17 |
Rick-
Thank you! I found that it was a library build problem and remedied it with binutils as you alluded to above. I ran wmake libso OpenFOAM in the src directory and it worked great. However, when I go back up to the main directory and do ./Allwmake, I get the new following error: doug@dell-neng-usu-edu:~/OpenFOAM/OpenFOAM-1.4$ ./Allwmake + cd wmake + ./makeWmake make: Nothing to be done for `all'. + cd src + ./Allwmake + cd /home/doug/OpenFOAM/OpenFOAM-1.4/src/OpenFOAM + wmakeLnInclude . + wmake libso zlib-1.2.1 `/home/doug/OpenFOAM/OpenFOAM-1.4/lib/linuxGcc4DPOpt/libz.so' is up to date. + wmake libso foamUser `/home/doug/OpenFOAM/OpenFOAM-1.4/lib/linuxGcc4DPOpt/libfoamUser.so' is up to date. + '[' LAM = OPENMPI -a '!' -r /lib/libmpi.a -a '!' -r /lib/libmpi.so ']' + '[' LAM = LAM -a '!' -r /home/doug/OpenFOAM/OpenFOAM-1.4/src/lam-7.1.2/platforms/linuxGcc4DPOpt/lib/libm pi.a -a '!' -r /home/doug/OpenFOAM/OpenFOAM-1.4/src/lam-7.1.2/platforms/linuxGcc4DPOpt/lib/libm pi.so ']' + '[' LAM = MPICH -a '!' -r /lib/libmpich.a -a '!' -r /lib/libmpich.so ']' + cd Pstream + ./Allwmake + wmake libso dummy `/home/doug/OpenFOAM/OpenFOAM-1.4/lib/linuxGcc4DPOpt/dummy/libPstream.so' is up to date. + '[' LAM = LAM -o LAM = OPENMPI -o LAM = MPI -o LAM = MPICH -o LAM = MPICH-GM ']' + export WM_OPTIONS=linuxGcc4DPOptLAM + WM_OPTIONS=linuxGcc4DPOptLAM + wmake libso mpi `/home/doug/OpenFOAM/OpenFOAM-1.4/lib/linuxGcc4DPOpt/lam-7.1.2/libPstream.so' is up to date. + wmake libso OpenFOAM `/home/doug/OpenFOAM/OpenFOAM-1.4/lib/linuxGcc4DPOpt/libOpenFOAM.so' is up to date. + wmake libso lagrangian/basic `/home/doug/OpenFOAM/OpenFOAM-1.4/lib/linuxGcc4DPOpt/liblagrangian.so' is up to date. + wmake libso triSurface SOURCE=triSurface/interfaces/STL/readSTLASCII.L ; flex++ -f $SOURCE ; mv lex.yy.cc Make/linuxGcc4DPOpt/readSTLASCII.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IlnInclude -I. -I/home/doug/OpenFOAM/OpenFOAM-1.4/src/OpenFOAM/lnInclude -fPIC -pthread -c Make/linuxGcc4DPOpt/readSTLASCII.C -o Make/linuxGcc4DPOpt/readSTLASCII.o /bin/sh: flex++: command not found mv: cannot stat `lex.yy.cc': No such file or directory g++: Make/linuxGcc4DPOpt/readSTLASCII.C: No such file or directory g++: no input files make: *** [Make/linuxGcc4DPOpt/readSTLASCII.o] Error 1 + wmake libso edgeMesh `/home/doug/OpenFOAM/OpenFOAM-1.4/lib/linuxGcc4DPOpt/libedgeMesh.so' is up to date. + wmake libso meshTools /usr/bin/ld: cannot find -ltriSurface collect2: ld returned 1 exit status make: *** [/home/doug/OpenFOAM/OpenFOAM-1.4/lib/linuxGcc4DPOpt/libmeshTools.so] Error 1 + wmake libso finiteVolume I've never heard of flex++, but it seems like I don't have some utility installed that contains flex++. Any ideas anyone? Thanks. -doug |
May 22, 2007, 18:35 |
flex++ is usually the same exe
Mattijs Janssens
Rep Power: 26 |
flex++ is usually the same executable as flex (on my machine it is a softlink to flex). It produces a parser using C++ instead of C.
September 25, 2008, 08:20 |
I also get lots of these:
BastiL
Rep Power: 20 |
/usr/bin/ld: cannot find messages during compiling OF 1.5.x. The script contiunues with some of them but finally stops with another of these errors. I have binutils installed on my Gentoo x86_64 System. The wiki tells to rerun ./Allwmake in the source directory once more. If I do this without running "wcleanAll" before I get lots of errors. If I run "wcleanAll" I am struggeling with exactly the same errors. Any ideas? |
January 1, 2009, 23:02 |
Hi ppl
I am running into th
Alexandre Pereira
Rep Power: 17 |
Hi ppl
I am running into the same kindo of probls, trying to compile OF-1.5.x... my ThirdParty folder is the default of OF-1.5, I have binutils and flex installed... I am running allwmake in a Ubuntu 7.10... the last lib to be built was libKineticTheoryModel.so... before build errors started appearing... What is wrong with OF-1.5.x...? I successfully compiled OF-1.5-dev... Best regards Alex |
February 18, 2010, 11:22 |
Nick Gardiner
Rep Power: 17 |
Does anyone know how to get round this problem? I have it on 64bit Ubuntu when trying to install the OpenFOAM-1.5-dev.General_2009-12-11.tgz
from http://powerlab.fsb.hr/ped/kturbo/OpenFOAM/release/ I've successfully installed all the third party apps have flex, flex++, binutils, etc, etc but still no luck. I know it's to do with the ld linker but don't know how to fix it |
February 19, 2010, 08:29 |
Gijsbert Wierink
Rep Power: 18 |
Hi Nick,
I just successfully installed OF-1.5-dev on 64 bit Ubuntu 9.10 and had some similar problem at first. It turned out I forgot to install binutils-dev. Are you sure you have that package as well?
Regards, Gijs |
February 23, 2010, 08:24 |
#9 |
Nick Gardiner
Rep Power: 17 |
Thanks Gijsbert
Compiled with no errors! There's a first time for everything... |
October 7, 2010, 11:24 |
Trouble with compiling 1.5-dev
#10 |
P.A.
Rep Power: 17 |
Hi Foamers,
I see some people had this kind of trouble before, but none of the solutions seems to suit my case. I am trying to compile the same package as NickG and run into the same linker errors saying ...blah -lfiniteVolume -lOpenFOAM -liberty -ldl -lm -o /home/ofuser/OpenFOAM/OpenFOAM-1.5-dev/applications/bin/linux64GccDPOpt/sonicLiquidFoam /usr/bin/ld: cannot find -lfiniteVolume collect2: ld returned 1 exit status I am running a CentOS cluster with 2.6.18-128.4.1.el5 kernel and had no problems with later versions of OF (like 1.6.x or 1.7.1). I have binutils and binutils-devel-2.17.50.0.6-14.el5.x86_64 installed, I use gcc-4.4 (freshly compiled). I fixed the strange <<<<<... entries in the etc/bashrc and put a softlink in the ThirdParty directory so that openmpi-1.3.3 redirects to the actually existing openmpi-1.2.6. $PATH looks like this: /bin:/home/ofuser/OpenFOAM/ThirdParty-1.5-dev/openmpi-1.3.3/platforms/linux64GccDPOpt/bin:/home/ofuser/OpenFOAM/ofuser-1.5-dev/applications/bin/linux64GccDPOpt:/home/ofuser/OpenFOAM/OpenFOAM-1.5-dev/applications/bin/linux64GccDPOpt:/home/ofuser/OpenFOAM/OpenFOAM-1.5-dev/wmake:/home/ofuser/OpenFOAM/OpenFOAM-1.5-dev/bin:/usr/kerberos/bin:/usr/local/bin:/usr/bin:/opt/ofed/bin:/opt/ofed/sbin:/home/ofuser/bin When I follow the hint to run Allwmake in the source directory again, I get this: ...(snippet)... + wmake libo OSspecific/Unix SOURCE=signals/sigFpe.C ; g++ -m64 -Dlinux64 -DDP -DFOAM_DEV_REVISION_NUMBER=exported -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -IlnInclude -I. -I/home/ofuser/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude -I/home/ofuser/OpenFOAM/OpenFOAM-1.5-dev/src/OSspecific/Unix/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/sigFpe.o signals/sigFpe.C: In static member function ���static void* Foam::sigFpe::my_malloc_hook(size_t, const void*)���: signals/sigFpe.C:85: error: ���uint64_t��� does not name a type signals/sigFpe.C:89: error: ���uint64_t��� was not declared in this scope signals/sigFpe.C:89: error: ���dPtr��� was not declared in this scope signals/sigFpe.C:89: error: expected type-specifier before ���uint64_t��� signals/sigFpe.C:89: error: expected ���>��� before ���uint64_t��� signals/sigFpe.C:89: error: expected ���(��� before ���uint64_t��� signals/sigFpe.C:89: error: expected primary-expression before ���>��� token signals/sigFpe.C:89: error: expected ���)��� before ���;��� token signals/sigFpe.C:93: error: ���sNAN��� was not declared in this scope make: *** [Make/linux64GccDPOpt/sigFpe.o] Error 1 + wmake libso OpenFOAM SOURCE=global/global.Cver ; sed s/WM_PROJECT_VERSION/\"1.5-dev\"/ $SOURCE > Make/linux64GccDPOpt/global.C ; g++ -m64 -Dlinux64 -DDP -DFOAM_DEV_REVISION_NUMBER=exported -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/home/ofuser/OpenFOAM/ThirdParty-1.5-dev/zlib-1.2.3 -IlnInclude -I. -I/home/ofuser/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude -I/home/ofuser/OpenFOAM/OpenFOAM-1.5-dev/src/OSspecific/Unix/lnInclude -fPIC -c Make/linux64GccDPOpt/global.C -o Make/linux64GccDPOpt/global.o g++: /home/ofuser/OpenFOAM/OpenFOAM-1.5-dev/lib/linux64GccDPOpt/libOSspecific.o: No such file or directory make: *** [/home/ofuser/OpenFOAM/OpenFOAM-1.5-dev/lib/linux64GccDPOpt/libOpenFOAM.so] Error 1 ...(snippet end)... After this, some outputs states that things are all well again, like: + wmake libso lduSolvers '/home/ofuser/OpenFOAM/OpenFOAM-1.5-dev/lib/linux64GccDPOpt/liblduSolvers.so' is up to date. + wmake libso lagrangian/basic '/home/ofuser/OpenFOAM/OpenFOAM-1.5-dev/lib/linux64GccDPOpt/liblagrangian.so' is up to date. Then again compilation of meshTools causes trouble: ...(snippet)... + wmake libso meshTools SOURCE=triSurface/surfaceFeatures/surfaceFeatures.C ; g++ -m64 -Dlinux64 -DDP -DFOAM_DEV_REVISION_NUMBER=exported -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/home/ofuser/OpenFOAM/OpenFOAM-1.5-dev/src/triSurface/lnInclude -I/home/ofuser/OpenFOAM/OpenFOAM-1.5-dev/src/lagrangian/basic/lnInclude -IlnInclude -I. -I/home/ofuser/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude -I/home/ofuser/OpenFOAM/OpenFOAM-1.5-dev/src/OSspecific/Unix/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/surfaceFeatures.o triSurface/surfaceFeatures/surfaceFeatures.C: In member function ���Foam::Map<int> Foam::surfaceFeatures::nearestSamples(const Foam::labelList&, const Foam:ointField&, const Foam::scalarField&) const���: triSurface/surfaceFeatures/surfaceFeatures.C:770: error: conflicting declaration ���Foam:ctreeDataPoint samples��� triSurface/surfaceFeatures/surfaceFeatures.C:769: error: ���samples��� has a previous declaration as ���Foam::treeBoundBox samples��� triSurface/surfaceFeatures/surfaceFeatures.C: In member function ���Foam::Map<int> Foam::surfaceFeatures::nearestSamples(const Foam::labelList&, const Foam:ointField&, const Foam::scalarField&, const Foam::scalarField&, Foam::scalar) const���: triSurface/surfaceFeatures/surfaceFeatures.C:871: error: conflicting declaration ���Foam:ctreeDataPoint samples��� triSurface/surfaceFeatures/surfaceFeatures.C:870: error: ���samples��� has a previous declaration as ���Foam::treeBoundBox samples��� make: *** [Make/linux64GccDPOpt/surfaceFeatures.o] Error 1 + wmake libso finiteVolume /usr/bin/ld: cannot find -lmeshTools collect2: ld returned 1 exit status make: *** [/home/ofuser/OpenFOAM/OpenFOAM-1.5-dev/lib/linux64GccDPOpt/libfiniteVolume.so] Error 1 ...(snippet end)... and so on! What am I missing? I am completely lost with this trouble! Thanks a lot! Cheers, Pascal. |
October 7, 2010, 19:42 |
#11 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Pascal,
I've got a feeling that your gcc 4.4 is not visible to your OpenFOAM 1.5-dev I don't see any path to it the PATH variable! Where exactly is your gcc 4.4? What does "gcc --version" output? Best regards, Bruno
October 8, 2010, 11:22 |
#12 |
P.A.
Rep Power: 17 |
Hi Bruno,
yeah, would have been a nice bummer! ;-) The gcc -dumpversion gives 4.4.5, and it is under /usr/local/bin, which is confirmed by "which" command. When I do all the commands in Allwmake by hand, things start to fail when processing the stuff in the src directory. The following errors come up immediately: ....... (snippet) ......... SOURCE=signals/sigFpe.C ; g++ -m64 -Dlinux64 -DDP -DFOAM_DEV_REVISION_NUMBER=exported -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -IlnInclude -I. -I/home/ofuser/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude -I/home/ofuser/OpenFOAM/OpenFOAM-1.5-dev/src/OSspecific/Unix/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/sigFpe.o signals/sigFpe.C: In static member function ���static void* Foam::sigFpe::my_malloc_hook(size_t, const void*)���: signals/sigFpe.C:85: error: ���uint64_t��� does not name a type signals/sigFpe.C:89: error: ���uint64_t��� was not declared in this scope signals/sigFpe.C:89: error: ���dPtr��� was not declared in this scope signals/sigFpe.C:89: error: expected type-specifier before ���uint64_t��� signals/sigFpe.C:89: error: expected ���>��� before ���uint64_t��� signals/sigFpe.C:89: error: expected ���(��� before ���uint64_t��� signals/sigFpe.C:89: error: expected primary-expression before ���>��� token signals/sigFpe.C:89: error: expected ���)��� before ���;��� token signals/sigFpe.C:93: error: ���sNAN��� was not declared in this scope make: *** [Make/linux64GccDPOpt/sigFpe.o] Error 1 ............ (snippet end) .......... Is there something wrong with some 64-bit libraries on my system? A bit later the following files cannot be created: libOSspecific.o libfiniteVolume.so libdynamicMesh.so libfvMotionSolver.so libfaceDecompositionMotionSolver.so libsampling.so libdynamicFvMesh.so libengine.so libODE.so librandomProcesses.so libbasicThermophysicalModels.so liblaminarFlameSpeedModels.so libchemistryModel.so libradiation.so and some more, which seems to be caused by the absence of "-lfiniteVolume" or "-ldynamicMesh" or "-lmeshTools" (at least the linker cannot find them). Nevertheless, there are quite a lot of shared object files in the respective directory /home/ofuser/OpenFOAM/OpenFOAM-1.5-dev/lib/linux64GccDPOpt/ So, something in the build of those libraries goes wrong. But what?????????????? Thanks a lot for the input! Best regards, Pascal. |
October 8, 2010, 11:53 |
#13 |
Bruno Santos
Rep Power: 128 |
Hi Pascal,
There are only a few possibilities left, as far as I can tell:
I don't say 1.7's ThirdParty, because with 1.7 things are a bit different and would require some additional tweaking. Best regards, Bruno
October 8, 2010, 12:39 |
#14 |
Travis Carrigan
Rep Power: 16 |
Digging around I found the solution to this problem.
If using Ubuntu, install these packages: gcc, binutils-dev, flex, build-essential, python-dev, libqt4-dev, libreadline5-dev, zlib1g-dev, cmake If using CentOS (RHEL), install the following: gcc, gcc-c++, bison, ncurses-devel, binutils-devel, tix.x86_64, glibc-devel, flex, flex-devel, zlib-devel, libXt-devel Everything seems to work afterward. |
November 1, 2010, 10:54 |
#15 |
N. A.
Rep Power: 16 |
Hi Bruno and Others,
I am getting a similar ld compileing error. Few weeks back our cluster creashed and they installed new operating system. I was able to run some cases in OF1.6. Yesterday I tried to compile some of the solvers and I ran into this ld exit problem that all are talking about. Do you know what could be done to rectify this error. my gcc version is 4.4.3 Eorror: _______________ NA@emerald:~/OpenFOAM/NA-1.6/applications/solvers/gasificationFoam$ wmake Making dependency list for source file gasificationFoam.C SOURCE=gasificationFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/meshTools/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/compressible/turbulenceModel -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/lagrangian/basic/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/lagrangian/intermediate/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/lagrangian/coalCombustion/lnInclude -I/home/NA/OpenFOAM/NA-1.6/src/mycoalCombustion/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/pdfs/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/specie/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/basic/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/liquids/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/liquidMixture/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/solids/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/solidMixture/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/thermophysicalFunctions/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/reactionThermo/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/chemistryModel/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/radiation/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/ODE/lnInclude -IlnInclude -I. -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/gasificationFoam.o g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/meshTools/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/compressible/turbulenceModel -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/lagrangian/basic/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/lagrangian/intermediate/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/lagrangian/coalCombustion/lnInclude -I/home/NA/OpenFOAM/NA-1.6/src/mycoalCombustion/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/pdfs/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/specie/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/basic/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/liquids/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/liquidMixture/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/solids/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/solidMixture/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/thermophysicalFunctions/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/reactionThermo/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/chemistryModel/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/radiation/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/ODE/lnInclude -IlnInclude -I. -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC Make/linux64GccDPOpt/gasificationFoam.o -L/home/NA/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt \ -lfiniteVolume -lmeshTools -lcompressibleRASModels -lcompressibleLESModels -llagrangian -llagrangianIntermediate -L/home/NA/OpenFOAM/NA-1.6/lib/linux64GccDPOpt -lmycoalCombustion -lspecie -lbasicThermophysicalModels -lliquids -lliquidMixture -lsolids -lsolidMixture -lthermophysicalFunctions -lreactionThermophysicalModels -lchemistryModel -lradiation -lODE -lOpenFOAM -liberty -ldl -lm -o /home/NA/OpenFOAM/NA-1.6/applications/bin/linux64GccDPOpt/gasificationFoam /usr/bin/ld: cannot find -liberty collect2: ld returned 1 exit status make: *** [/home/NA/OpenFOAM/NA-1.6/applications/bin/linux64GccDPOpt/gasificationFoam] Error 1 ________________ Thanks, Nir |
November 1, 2010, 13:06 |
#16 |
Bruno Santos
Rep Power: 128 |
Hi Nir,
You have two choices:
Bruno
November 1, 2010, 18:35 |
#17 |
N. A.
Rep Power: 16 |
Hi Bruno,
Thanks. I tired option#2 that you suggested, but it some I am getting a kind of error that is trying to recosgnize some unkown characters when I compile the solver and both the source code (in OpenFOAM-1.6 version). Strangely the error remains even if I keep the "-liberty" option in the ~wmake/rules/linxGcc/general. Following is the error: common_file_compress.c:62:18: error: zlib.h: No such file or directory common_file_compress.c: In function ‘fileCompressGz’: common_file_compress.c:283: error: ‘gzFile’ undeclared (first use in this function) common_file_compress.c:283: error: (Each undeclared identifier is reported only once common_file_compress.c:283: error: for each function it appears in.) common_file_compress.c:283: error: expected ‘;’ before ‘gzfile’ common_file_compress.c:286: error: ‘gzfile’ undeclared (first use in this function) common_file_compress.c:286: warning: implicit declaration of function ‘gzdopen’ common_file_compress.c:290: warning: implicit declaration of function ‘gzsetparams’ common_file_compress.c:290: error: ‘Z_DEFAULT_STRATEGY’ undeclared (first use in this function) common_file_compress.c:293: warning: implicit declaration of function ‘gzwrite’ common_file_compress.c:301: warning: implicit declaration of function ‘gzclose’ make: *** [Make/linux64GccDPOpt/common_file_compress.o] Error 1 These " †" kind of cahrates appear for during whol of compilation (both the source code and the solvers". Can you suggest what this error could be and how I can rectify it? Thanks, Nir |
November 1, 2010, 22:00 |
#18 |
N. A.
Rep Power: 16 |
Hi Bruno,
So I have a new error in compiling solvers, which I was able to do before. I am not sure what happened? Can you please point me to what could be the source of this error. I am guessing this is not related to the -liberty option with general file (of the wmake/rules/linux64Gcc) directory as irrespective of that I see there is a compilation error: Error: ________ SOURCE=gasificationFoam.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/meshTools/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/compressible/turbulenceModel -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/lagrangian/basic/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/lagrangian/intermediate/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/lagrangian/coalCombustion/lnInclude -I/home/NA/OpenFOAM/NA-1.6/src/mycoalCombustion/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/pdfs/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/specie/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/basic/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/liquids/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/liquidMixture/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/solids/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/solidMixture/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/thermophysicalFunctions/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/reactionThermo/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/chemistryModel/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/radiation/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/ODE/lnInclude -IlnInclude -I. -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/home/NA/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/gasificationFoam.o In file included from gasificationFoam.C:101: hEqn.H: In function ‘int main(int, char**)’: hEqn.H:9: error: no match for ‘operator+’ in ‘Foamerator/(const Foam::GeometricField<double, PatchField, GeoMesh>&, const Foam::GeometricField<double, PatchField, GeoMesh>&) [with PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh](((const Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&)((const Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>*)(& rho)))) + Foamerator/(const Foam::tmp<Foam:imensionedField<double, GeoMesh> >&, const Foam:imensionedField<double, GeoMesh>&) [with GeoMesh = Foam::volMesh](((const Foam:imensionedField<double, Foam::volMesh>&)((const Foam:imensionedField<double, Foam::volMesh>*)(& rho.Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::<anonymous>))))’ /home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/dictionary.H:450: note: candidates are: Foam::dictionary Foamerator+(const Foam::dictionary&, const Foam::dictionary&) /home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/dimensionSet.H:250: note: Foam::dimensionSet Foamerator+(const Foam::dimensionSet&, const Foam::dimensionSet&) /home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/dimensionedScalar.H:50: note: Foam::dimensionedScalar Foamerator+(const Foam::dimensionedScalar&, Foam::scalar) /home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/dimensionedScalar.H:51: note: Foam::dimensionedScalar Foamerator+(Foam::scalar, const Foam::dimensionedScalar&) /home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/scalarField.H:78: note: Foam::tmp<Foam::Field<double> > Foamerator+(const Foam::scalar&, const Foam::UList<double>&) /home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/scalarField.H:78: note: Foam::tmp<Foam::Field<double> > Foamerator+(const Foam::scalar&, const Foam::tmp<Foam::Field<double> >&) /home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/scalarField.H:78: note: Foam::tmp<Foam::Field<double> > Foamerator+(const Foam::UList<double>&, const Foam::scalar&) /home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/scalarField.H:78: note: Foam::tmp<Foam::Field<double> > Foamerator+(const Foam::tmp<Foam::Field<double> >&, const Foam::scalar&) /home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/labelField.H:54: note: Foam::tmp<Foam::Field<int> > Foamerator+(const Foam::label&, const Foam::UList<int>&) /home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/labelField.H:54: note: Foam::tmp<Foam::Field<int> > Foamerator+(const Foam::label&, const Foam::tmp<Foam::Field<int> >&) /home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/labelField.H:54: note: Foam::tmp<Foam::Field<int> > Foamerator+(const Foam::UList<int>&, const Foam::label&) /home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/labelField.H:54: note: Foam::tmp<Foam::Field<int> > Foamerator+(const Foam::tmp<Foam::Field<int> >&, const Foam::label&) /home/NA/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/specie/lnInclude/specieI.H:150: note: Foam::specie Foamerator+(const Foam::specie&, const Foam::specie&) /home/NA/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/specie/lnInclude/perfectGasI.H:110: note: Foam:erfectGas Foamerator+(const Foam:erfectGas&, const Foam:erfectGas&) hEqn.H:12: error: no match for ‘operator/’ in ‘Foam::radiation::radiationModel::Sh(((Foam::bas icThermo&)(&((Foam::hCombustionThermo*)thermo)->Foam::hCombustionThermo::<anonymous>.Foam::basicP siThermo::<anonymous>))) / rho’ /home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/fileName.H:183: note: candidates are: Foam::fileName Foamerator/(const Foam::string&, const Foam::string&) /home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/dimensionSet.H:268: note: Foam::dimensionSet Foamerator/(const Foam::dimensionSet&, const Foam::dimensionSet&) /home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/dimensionedScalar.H:57: note: Foam::dimensionedScalar Foamerator/(Foam::scalar, const Foam::dimensionedScalar&) /home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/scalarField.H:82: note: Foam::tmp<Foam::Field<double> > Foamerator/(const Foam::UList<double>&, const Foam::UList<double>&) /home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/scalarField.H:82: note: Foam::tmp<Foam::Field<double> > Foamerator/(const Foam::UList<double>&, const Foam::tmp<Foam::Field<double> >&) /home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/scalarField.H:82: note: Foam::tmp<Foam::Field<double> > Foamerator/(const Foam::tmp<Foam::Field<double> >&, const Foam::UList<double>&) /home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/scalarField.H:82: note: Foam::tmp<Foam::Field<double> > Foamerator/(const Foam::tmp<Foam::Field<double> >&, const Foam::tmp<Foam::Field<double> >&) /home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/scalarField.H:84: note: Foam::tmp<Foam::Field<double> > Foamerator/(const Foam::scalar&, const Foam::UList<double>&) /home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/scalarField.H:84: note: Foam::tmp<Foam::Field<double> > Foamerator/(const Foam::scalar&, const Foam::tmp<Foam::Field<double> >&) /home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/sphericalTensorField.H:59: note: Foam::tmp<Foam::Field<Foam::SphericalTensor<double > > > Foamerator/(const Foam::UList<double>&, const Foam::UList<Foam::SphericalTensor<double> >&) /home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/sphericalTensorField.H:59: note: Foam::tmp<Foam::Field<Foam::SphericalTensor<double > > > Foamerator/(const Foam::UList<double>&, const Foam::tmp<Foam::Field<Foam::SphericalTensor<double > > >&) /home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/sphericalTensorField.H:59: note: Foam::tmp<Foam::Field<Foam::SphericalTensor<double > > > Foamerator/(const Foam::tmp<Foam::Field<double> >&, const Foam::UList<Foam::SphericalTensor<double> >&) /home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/sphericalTensorField.H:59: note: Foam::tmp<Foam::Field<Foam::SphericalTensor<double > > > Foamerator/(const Foam::tmp<Foam::Field<double> >&, const Foam::tmp<Foam::Field<Foam::SphericalTensor<double > > >&) /home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/sphericalTensorField.H:60: note: Foam::tmp<Foam::Field<Foam::SphericalTensor<double > > > Foamerator/(const Foam::scalar&, const Foam::UList<Foam::SphericalTensor<double> >&) /home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/sphericalTensorField.H:60: note: Foam::tmp<Foam::Field<Foam::SphericalTensor<double > > > Foamerator/(const Foam::scalar&, const Foam::tmp<Foam::Field<Foam::SphericalTensor<double > > >&) /home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/sphericalTensorField.H:60: note: Foam::tmp<Foam::Field<Foam::SphericalTensor<double > > > Foamerator/(const Foam::UList<double>&, const Foam::sphericalTensor&) /home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/sphericalTensorField.H:60: note: Foam::tmp<Foam::Field<Foam::SphericalTensor<double > > > Foamerator/(const Foam::tmp<Foam::Field<double> >&, const Foam::sphericalTensor&) /home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/tensorField.H:79: note: Foam::tmp<Foam::Field<Foam::Vector<double> > > Foamerator/(const Foam::UList<Foam::Vector<double> >&, const Foam::UList<Foam::Tensor<double> >&) /home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/tensorField.H:79: note: Foam::tmp<Foam::Field<Foam::Vector<double> > > Foamerator/(const Foam::UList<Foam::Vector<double> >&, const Foam::tmp<Foam::Field<Foam::Tensor<double> > >&) /home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/tensorField.H:79: note: Foam::tmp<Foam::Field<Foam::Vector<double> > > Foamerator/(const Foam::tmp<Foam::Field<Foam::Vector<double> > >&, const Foam::UList<Foam::Tensor<double> >&) /home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/tensorField.H:79: note: Foam::tmp<Foam::Field<Foam::Vector<double> > > Foamerator/(const Foam::tmp<Foam::Field<Foam::Vector<double> > >&, const Foam::tmp<Foam::Field<Foam::Tensor<double> > >&) /home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/tensorField.H:80: note: Foam::tmp<Foam::Field<Foam::Vector<double> > > Foamerator/(const Foam::vector&, const Foam::UList<Foam::Tensor<double> >&) /home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/tensorField.H:80: note: Foam::tmp<Foam::Field<Foam::Vector<double> > > Foamerator/(const Foam::vector&, const Foam::tmp<Foam::Field<Foam::Tensor<double> > >&) /home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/tensorField.H:80: note: Foam::tmp<Foam::Field<Foam::Vector<double> > > Foamerator/(const Foam::UList<Foam::Vector<double> >&, const Foam::tensor&) /home/NA/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/tensorField.H:80: note: Foam::tmp<Foam::Field<Foam::Vector<double> > > Foamerator/(const Foam::tmp<Foam::Field<Foam::Vector<double> > >&, const Foam::tensor&) make: *** [Make/linux64GccDPOpt/gasificationFoam.o] Error 1 _____________ (*note: Foamerator if Foam: Operator above. Due to smiley's Op is removed) Thanks, Nir |
November 2, 2010, 18:50 |
#19 | |
Bruno Santos
Rep Power: 128 |
Hi Nir,
As for the other problem with gasificationFoam, try: Code:
wclean wmake Best regards, Bruno
November 4, 2010, 15:15 |
#20 |
N. A.
Rep Power: 16 |
Bruno,
Thanks. I think the -liberty option works great. -Nir |
Compilation error usrbinld cannot find lXext | andpet | OpenFOAM Installation | 2 | May 16, 2008 08:48 |
where i can find? | khalil khanagarayah | Main CFD Forum | 0 | March 4, 2003 12:03 |
where i can find | atique-ur-rehman | Main CFD Forum | 2 | March 2, 2003 11:40 |
where i can find? | S. Sulaksana | Main CFD Forum | 0 | January 18, 2003 05:01 |
where i can find? | sulaksana | Main CFD Forum | 0 | September 13, 2002 06:22 |
