OpenFOAM15 on Ubuntu810
Old   December 23, 2008, 06:49
Default Hello, This is the rig
  #21
Suresh kumar Kannan
kumar is on a distinguished road
This is the right link i was talking about. Use the second script as it is updated one. I used the same script to install OF-1.5 on 8.10 Ubuntu. So it should work for you as well well. But the installation will take long time, so i suggest you to wait till it asks for restarting the system.
Note: before running the script make sure to install sudo and apt from the synaptics package manager.
bye
K.Suresh kumar
kumar is offline   Reply With Quote
Old   December 23, 2008, 07:40
Default Hello Suresh, Thanks for you
  #22
Maruthamuthu Venkatraman
maruthamuthu_venkatraman is on a distinguished road
Hello Suresh,
Thanks for your feedback. Actually i dont know about this sudo and apt . If you can send me the link where shall i find this packages in web and in which directory should i install it will help me.
Also to run the script, should i run in terminal by typing " bash <file> " from the home directory. pls clarify.
maruthamuthu_venkatraman is offline   Reply With Quote
Old   December 23, 2008, 09:21
Default Hello, I will explain
  #23
Suresh kumar Kannan
I will explain the installation in steps:
1. Go to system (menu) on your Ubuntu desktop sidebar and then select (Synaptic package Manager) (it may ask for your password), this tool is used to install packages in Ubuntu. I suggest you to always use this package manager to install packages.
2. search for sudo (this package allows you to provide super user privileges to specific users). Just click it and install it.
3.similarly search for apt . You will find it, and click it for install.
Regarding the script:
1.Just copy all the contents and put it in to a file.
2. then change the file to an executable file using chmod a+x file name.
3.then execute the file from the command line as this
./filename
this will go to the corresponding website and download the software and will ask you for password before installing it.
bye
K.Suresh kumar
Old   December 25, 2008, 18:39
Default Dear Suresh, Tha
  #24
Dear Suresh,
Thanks a Lot for your vivid illustration of OPENFOAM 1.5 installation in UBUNTU 8.10. The script file works when i followed your instructions. Also the src directory i deleted before running this script. Then QT 4.3.5 is installed properly and paraview also executes correctly.Cavity tutorial is working fine.
This Discussion Forum really works.
Regards,
Muthu
Old   January 6, 2009, 22:16
Default hi foamers! thanks also for t
  #25
Peter Canfield
canfield is on a distinguished road
hi foamers!
thanks also for the installation script. it makes installing 1.5 version much simpler. i have been working with v1.5 already, but i really want to use the coupling utilities in the development version. i am now getting close to successfully compiling the 1.5-dev version. but after unpacking the openfoam-1.5-dev.tar file and compiling twice i still get one error after executing foamInstallationTest:
Third party software
Software Version Location
WARNING: gcc version does not match gcc supplied with this release of OpenFOAM
Supplied version: 4.3.1
User version : ../src/configure
Minimum required: 4.2.0
gcc ...figure
WARNING: Conflicting installations:
OpenFOAM settings : /bin/gcc
current path : /usr/bin/gcc
CRITICAL ERROR
gzip 1.3.12 /bin/gzip
tar 1.20 /bin/tar
Segmentation fault
icoFoam 1.5 ...penFOAM-1.5-dev/applications/bin/linuxGccDPOpt/icoFoam
Checking networking...
Action Result Crit
Pinging_peter-laptop Successful yes
Pinging_localHost Successful yes
Test_rsh: Unsuccessful_connection_refused* yes
Test_ssh: Successful yes
(*) Only one of rsh or ssh is required by the OpenFOAM enviroment.
Base configuration ok.
The foam installation contains 1 critical error(s).
any help would be great.
PC
canfield is offline   Reply With Quote
Old   January 12, 2009, 07:33
Default all it means is that OpenFOAM
  #26
Zairja
zairja is on a distinguished road
all it means is that OpenFOAM is looking for gcc at /bin/gcc by default and your path is /usr/bin/gcc.
to ensure that both are identical try setting the following in the terminal before you run the foamInstallationTest command:
export WM_COMPILER_DIR <path>
Path is where you have actually compiled or installed gcc.
Hope this will help you....cheers
zairja is offline   Reply With Quote
Old   January 16, 2009, 15:41
Default Hi, I have solved Qt problem
  #27
Krzysztof Przysowa
kprzysowagmailcom is on a distinguished road
I have solved Qt problem as written on:
http://www.opencfd.co.uk/openfoam/doc/README.html#Qt
The crucial is the following sentence:
Compilation and running of ParaView has been successful using the libraries downloaded in the "libqt4-dev" package on ubuntu.
kprzysowagmailcom is offline   Reply With Quote
Old   January 25, 2009, 09:01
Default @PC: Open ~/OpenFOAM/OpneFOAM
  #28
Marco Moscaritolo
mavimo is on a distinguished road
@PC:
Open ~/OpenFOAM/OpneFOAM-1.5/etc/bashrc and find:
. export WM_COMPILER_ARCH=
. export WM_COMPILER_LIB_ARCH=
After that add this line:
. export WM_COMPILER_DIR=/usr
save, close shell and reopen it.
Bye
MVM
mavimo is offline   Reply With Quote
Old   January 25, 2009, 09:05
Default ok, i find correct package: .
  #29
Marco Moscaritolo
. libmpfr-dev
. libmpfi-dev
(and their dependences)
Bye
MVM
OpenFOAM15 paraFoam bug koen OpenFOAM Bugs 19 June 30, 2009 11:46
BuildParaView Error in Ubuntu810 liangyuly OpenFOAM Installation 2 February 26, 2009 03:08
Fedora 10 OpenFOAM15 philippose OpenFOAM Installation 7 February 18, 2009 05:37
ReconstructPar in OpenFOAM15 nicasch OpenFOAM Post-Processing 1 November 7, 2008 05:06
Updates for OpenFOAM15 olesen OpenFOAM Installation 9 July 18, 2008 04:18
