[OpenFOAM.org] X Server does not work on WSL2
Like Tree3Likes
  • 1 Post By olesen
  • 1 Post By Yann
  • 1 Post By alexvaleije
Old   April 19, 2023, 18:06
Default X Server does not work on WSL2
Luca
xisluke is on a distinguished road
Hi guys, I'm trying to install OpenFOAM 10 on Ubuntu 22.04 LTS, I'm running Linux on the WSL2, Windows 10.
I followed the exact instructions enlighted at the official link from The OpenFOAM Foundation (https://openfoam.org/download/windows/). Everything is fine until the enabling of graphical application; as I stated before, I followed exactly the same procedure by installing VcXsrv, but if I try to run gedit or paraFoam, basically nothing is working. XLaunch is running in the background but the only thing I see is the pointer blinking on the terminal without any window opening. I already used OpenFOAM few times ago with WSL1 but I didn't experienced this issue.
The .bashrc file has these two strings at the end:
. /opt/openfoam10/etc/bashrc
export DISPLAY=<IP ADDRESS>:0
Some suggestions? I tried to search out on the web but I really didn't find something that really helped me, I am not used to work with Linux nor WSL.
Thanks!
xisluke is offline   Reply With Quote
Old   April 20, 2023, 04:45
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Related topics:
You are better to use a Windows installation of ParaView.
Yann likes this.
olesen is offline   Reply With Quote
Old   April 20, 2023, 05:07
Luca
Ok, let's say to install ParaView directly on Windows and solving the problem. How can I manage the issue with gedit?
Old   April 20, 2023, 05:46
Alejandro Valeije
alexvaleije is on a distinguished road
Hi Luca,
I do not get the question. Install paraview in Windows, and in the case folder generate a blank file with a ".openfoam" termination. For example, "case.openfoam".
Then, open that file with paraView and when it asks for the reader type, select OpenFoam Reader, and then your case will be loaded.
Much easier and better display than depending on the parafoam command and X acceleration
Hope that helps. Best regards,
alexvaleije is offline   Reply With Quote
Old   April 20, 2023, 06:26
Yann
Yann will become famous soon enoughYann will become famous soon enough
You can directly access your files from windows explorer and edit it using something like notepad++ or any other editor you like to use.
I would even say: create a blank file with the ".foam" extension rather than ".openfoam". It will be recognized by ParaView who will automatically use the OpenFOAM reader. (so you skip the part where you have to manually select the OpenFOAM reader in paraview when opening the case)
Cheers,
Yann
olesen likes this.
Yann is offline   Reply With Quote
Old   April 20, 2023, 07:30
Luca
Thank you guys, as I mentioned before I used OpenFOAM few times ago mainly at the university, professors told us to go with X Server and since I did not experienced any issues my intention was to go in the exact same way.
I would say that at that time I tried to modify directly in Windows some scripts, but I often got problems in the readability of the files in WSL, I do not remember the reason but the only way was gedit... It is also true that I was using Windows Notepad, not a more advanced editor like Notepad++ or Sublime Text
Old   April 20, 2023, 08:11
Alejandro Valeije
Without further information, I would say that those problems might have been caused by the carriage return that Windows Notepad does.
With Notepad++, or using nano in the terminal you should be safe. I know some people that likes vim, but I hate it so much hahaha
@Yann Nice trick the .foam instead .openfoam extension, I hadn't noticed so far
Yann likes this.
Old   April 20, 2023, 08:36
Yann
I agree with that. In notepad++ you can convert End Of Line characters to maintain the Linux format when editing the file from windows.
I've been doing this on a daily basis for years, no issues with it, as long as you remember to check it and convert from Windows to Linux if needed.
Notepad++ maintain the original format of the file so if you open OpenFOAM files with it it will be fine. You just need to be careful when creating a new file from windows.
Cheers,
Yann
[solids4Foam] elasticWallPressure no work in parallel. BC robin. Neb OpenFOAM CC Toolkits for Fluid-Structure Interaction 13 June 6, 2023 09:49
Home PC, Play, Work (CFD) - AMD7950x or i9-13900K without complicated settings? Mr.ZIMULAXION Hardware 3 March 7, 2023 08:20
parallel InterFoam solving does not work (single core does work) jordy OpenFOAM Running, Solving & CFD 0 February 2, 2023 08:11
Viscous Adjoint does not work AndreaMichelotti SU2 0 November 29, 2021 06:59
Installing SGE and getting CFX to work with it shreyasr Hardware 1 September 8, 2012 04:17
