[OpenFOAM.org] Problem Compiling openFOAM on WSL |
January 26, 2023, 11:41 |
Rep Power: 13 |
Hi everyone,
I am trying to compile openfoam on WSL2 using Ubuntu 20.04. Installing openfoam via packet manager (apt-get) works fine, compiling it myself does not. Already tried on WSL2 using Ubuntu 22.04. with same results. On a virtual machine with Ubuntu 22.04. compiling works just fine. Here some information that might be useful: lsb_release -a: Code:
No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu 20.04.5 LTS Release: 20.04 Codename: focal Code:
Using built-in specs. COLLECT_GCC=gcc COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/11/lto-wrapper OFFLOAD_TARGET_NAMES=nvptx-none:amdgcn-amdhsa OFFLOAD_TARGET_DEFAULT=1 Target: x86_64-linux-gnu Configured with: ../src/configure -v --with-pkgversion='Ubuntu 11.1.0-1ubuntu1~20.04' --with-bugurl=file:///usr/share/doc/gcc-11/README.Bugs --enable-languages=c,ada,c++,go,brig,d,fortran,objc,obj-c++,m2 --prefix=/usr --with-gcc-major-version-only --program-suffix=-11 --program-prefix=x86_64-linux-gnu- --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --enable-bootstrap --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-vtable-verify --enable-plugin --enable-default-pie --with-system-zlib --enable-libphobos-checking=release --with-target-system-zlib=auto --enable-objc-gc=auto --enable-multiarch --disable-werror --disable-cet --with-arch-32=i686 --with-abi=m64 --with-multilib-list=m32,m64,mx32 --enable-multilib --with-tune=generic --enable-offload-targets=nvptx-none=/build/gcc-11-2V7zgg/gcc-11-11.1.0/debian/tmp-nvptx/usr,amdgcn-amdhsa=/build/gcc-11-2V7zgg/gcc-11-11.1.0/debian/tmp-gcn/usr --without-cuda-driver --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu --with-build-config=bootstrap-lto-lean --enable-link-serialization=2 Thread model: posix Supported LTO compression algorithms: zlib zstd gcc version 11.1.0 (Ubuntu 11.1.0-1ubuntu1~20.04) Code:
/mnt/d/openFOAM/compileOF/OpenFOAM-10/src/OpenFOAM/lnInclude/List.C:46:37: error: ‘class Foam::List<char>’ has no member named ‘size_’; did you mean ‘size’? 46 | << "bad size " << this->size_ | ~~~~~~^~~~~ | size In file included from /mnt/d/openFOAM/compileOF/OpenFOAM-10/src/OpenFOAM/lnInclude/List.H:311, from /mnt/d/openFOAM/compileOF/OpenFOAM-10/src/OpenFOAM/lnInclude/HashTable.C:30, from /mnt/d/openFOAM/compileOF/OpenFOAM-10/src/OpenFOAM/lnInclude/HashTable.H:566, from /mnt/d/openFOAM/compileOF/OpenFOAM-10/src/OpenFOAM/lnInclude/objectRegistry.H:38, from /mnt/d/openFOAM/compileOF/OpenFOAM-10/src/OpenFOAM/lnInclude/time.h:42, from /usr/include/pthread.h:23, from /usr/include/x86_64-linux-gnu/c++/11/bits/gthr-default.h:35, from /usr/include/x86_64-linux-gnu/c++/11/bits/gthr.h:148, from /usr/include/c++/11/ext/atomicity.h:35, from /usr/include/c++/11/bits/basic_string.h:39, from /usr/include/c++/11/string:55, from /mnt/d/openFOAM/compileOF/OpenFOAM-10/src/OpenFOAM/lnInclude/string.H:51, from /mnt/d/openFOAM/compileOF/OpenFOAM-10/src/OpenFOAM/lnInclude/word.H:42, from /mnt/d/openFOAM/compileOF/OpenFOAM-10/src/OpenFOAM/lnInclude/int32.H:43, from /mnt/d/openFOAM/compileOF/OpenFOAM-10/src/OpenFOAM/lnInclude/int.H:38, from /mnt/d/openFOAM/compileOF/OpenFOAM-10/src/OpenFOAM/lnInclude/label.H:39, from /mnt/d/openFOAM/compileOF/OpenFOAM-10/src/OpenFOAM/lnInclude/labelList.H:47, from /mnt/d/openFOAM/compileOF/OpenFOAM-10/src/OpenFOAM/lnInclude/UPstream.H:42, from UPstream.C:26: /mnt/d/openFOAM/compileOF/OpenFOAM-10/src/OpenFOAM/lnInclude/ListI.H: In instantiation of ‘void Foam::List<T>::size(int) [with T = char]’: /mnt/d/openFOAM/compileOF/OpenFOAM-10/src/OpenFOAM/lnInclude/DynamicListI.H:45:18: required from ‘Foam::DynamicList<T, SizeInc, SizeMult, SizeDiv>::DynamicList(int) [with T = char; unsigned int SizeInc = 0; unsigned int SizeMult = 2; unsigned int SizeDiv = 1]’ /mnt/d/openFOAM/compileOF/OpenFOAM-10/src/OpenFOAM/lnInclude/ISstreamI.H:42:5: required from here /mnt/d/openFOAM/compileOF/OpenFOAM-10/src/OpenFOAM/lnInclude/ListI.H:166:15: error: ‘size_’ is not a member of ‘Foam::UList<char>’ 166 | UList<T>::size_ = n; | ^~~~~ /mnt/d/openFOAM/compileOF/OpenFOAM-10/src/OpenFOAM/lnInclude/ListI.H: In instantiation of ‘void Foam::List<T>::size(int) [with T = int]’: /mnt/d/openFOAM/compileOF/OpenFOAM-10/src/OpenFOAM/lnInclude/DynamicListI.H:377:31: required from ‘T& Foam::DynamicList<T, SizeInc, SizeMult, SizeDiv>::operator()(int) [with T = int; unsigned int SizeInc = 0; unsigned int SizeMult = 2; unsigned int SizeDiv = 1]’ /mnt/d/openFOAM/compileOF/OpenFOAM-10/src/OpenFOAM/lnInclude/UPstream.H:437:39: required from here /mnt/d/openFOAM/compileOF/OpenFOAM-10/src/OpenFOAM/lnInclude/ListI.H:166:15: error: ‘size_’ is not a member of ‘Foam::UList<int>’ make: *** [/mnt/d/openFOAM/compileOF/OpenFOAM-10/wmake/rules/General/transform:26: /mnt/d/openFOAM/compileOF/OpenFOAM-10/platforms/linux64GccDPInt32Opt/src/Pstream/dummy/UPstream.o] Error 1 Can also use a virtual machine to do OF programming but I like WSL much better. Best Regards, Leif |
what is problem my OpenFoam setting? | Lee97 | Main CFD Forum | 0 | September 1, 2022 09:57 |
If my problem diverges in OpenFOAM ver3, will it work in 5 | quarkz | OpenFOAM Running, Solving & CFD | 3 | April 26, 2018 03:09 |
[swak4Foam] problem in compiling groovyBC in OpenFoam 1.71 | javad814 | OpenFOAM Community Contributions | 4 | July 31, 2011 05:33 |
OpenFOAM Install problem | masb | OpenFOAM | 3 | May 25, 2009 12:32 |
Problem installing OpenFOAM 1.5 installation on RHEL 4. | vwsj84 | OpenFOAM Installation | 4 | April 23, 2009 05:48 |
