[OpenFOAM.org] "Official reader module form OpenFOAM Does not exist on your system"
Old   November 23, 2020, 13:23
Default "Official reader module form OpenFOAM Does not exist on your system"
malcolm
locutus is on a distinguished road
Hi Folks,
I recently followed the install instructions: https://openfoam.org/download/8-ubuntu/
Everything went smoothly right up until the last step where I entered what was given in the instructions into the terminal.
cd $FOAM_RUN
cp -r $FOAM_TUTORIALS/incompressible/simpleFoam/pitzDaily .
cd pitzDaily
blockMesh
simpleFoam
paraFoam
Here's the last chunk of the run:
SIMPLE solution converged in 287 iterations
streamLine streamlines write:
seeded 10 particles
Tracks:20
Total samples:12040
Writing data to "/home/maritza/OpenFOAM/maritza-8/run/pitzDaily/postProcessing/sets/streamlines/287"
writeObjects writeObjects(kEpsilon:G) write:
End
Inconsistency detected by ld.so: dl-close.c: 811: _dl_close: Assertion `map->l_init_called' failed!
maritza@maritza-K55DR ~/OpenFOAM/maritza-8/run/pitzDaily $ paraFoam
FATAL ERROR: The official reader module for OpenFOAM data does not exist on
your system. This means that the version of ParaView you are using was not
compiled with OpenFOAM, or distributed with a packaged version of OpenFOAM.
For information on packaged versions of OpenFOAM/ParaView and compilation of
OpenFOAM/ParaView, see https://openfoam.org/download
Alternatively, you might be able to view your OpenFOAM data with the reader
module provided with ParaView by running:
paraFoam -builtin
Can anyone offer a solution?
locutus is offline   Reply With Quote
Old   December 4, 2020, 17:36
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Just use the native reader. If you aren't happy with the paraview that comes with your system, grab a binary install from the kitware website. This becomes especially useful for older LTS systems.
I have a parafoam (all lowercase) that simply does a touch on log.foam and uses that for paraview.
EDIT: added a small list of pro/cons of plugins - do-i-really-need-the-paraview-plugins
olesen is offline   Reply With Quote
Getting Started with OpenFOAM wyldckat OpenFOAM 26 June 21, 2024 07:54
[OpenFOAM.org] paraView reader module build problem fusij OpenFOAM Installation 52 March 8, 2018 00:40
ParaView reader module libraries do not exist anishtain4 OpenFOAM Installation 5 October 9, 2012 09:25
OpenFOAM-2.0.x on Ubuntu 11.10 kpsl OpenFOAM Installation 43 January 19, 2012 00:17
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
