[OpenFOAM.com] Fedora openFoam2006 copr installation errors |
November 2, 2020, 17:58 |
Abe
Rep Power: 10 |
Hi Foamers,
I was really really excite to see ESI was offering precompiled binaries for Fedora, because I regularly have a very frustrating experience trying to compile from source twice a year. However, I can't install: Code:
Error: Problem: package openfoam2006-default-201012-201012.fc31.x86_64 requires openfoam2006-devel = 201012, but none of the providers can be installed - package openfoam2006-devel-201012-201012.fc31.noarch requires openfoam2006 = 201012, but none of the providers can be installed - conflicting requests - nothing provides libmpi.so.40()(64bit) needed by openfoam2006-201012-201012.fc31.x86_64 (try to add '--skip-broken' to skip uninstallable packages) Thanks |
November 3, 2020, 16:04 |
#2 | |
Mark Olesen
Rep Power: 40 |
It would be good we communicate on that for the final tests (you can be one the people to "sign-off" the changes if you wish). When the dust is finally settled we can either post a summary here, or a link to the solution. Thanks for bearing with us! EDIT: if you are desperate to install, you can override with allowing broken packages (the mpi problem is an "accounting" error) but the scotch bits were also busted. |
November 3, 2020, 16:45 |
Abe
Rep Power: 10 |
Ahh, that is interesting, I was having ptscotch troubles while trying to build from source. I have an old build that still works so I will give the copr version another try when its ready.
Thanks! |
November 4, 2020, 16:14 |
Abe
Rep Power: 10 |
I was able to install today! However, it didn't add the path. I was able to get things working by sourcing the bashrc in /usr/lib/openfoam/openfoam2006/etc, but I am getting the impression from the documentation that this is not the way things are intended to work. I read that the idea is to be able to install multiple versions alongside one another, and it seems like "openfoam-selector" should tell the system which bashrc to source? Is there any example of its usage? I tried
openfoam-selector --register v2006 --source-dir /usr/lib/openfoam/openfoam2006/ which failed. Anyway its nice to have a working install - thanks for supporting Fedora! |
November 13, 2020, 09:39 |
#5 | |
Mark Olesen
Rep Power: 40 |
openfoam-selector --register openfoam2006 --source-dir /usr/lib/openfoam/openfoam2006 --yes Try man openfoam-selector. If the examples need improvement, make suggestions. Probably the openfoam-selector-menu is easiest. Note that you probably still need to load your mpi modules too. In general, however, I would suggest the shell session as a good alternative. Code:
$ openfoam2006 Using: OpenFOAM-2006 (patch=201012) - visit www.openfoam.com Arch: linux64GccDPInt32Opt (mpi=openmpi-system) OpenFOAM shell session - use exit to quit |
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" | bigphil | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 686 | December 22, 2022 10:10 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 08:47 |
OpenFOAM 1.6 ext - Compilation errors - Fedora 17(32bit) | toolpost | OpenFOAM Installation | 15 | September 21, 2012 10:38 |
Critical errors gcc and icoFoam during installation of 15 | quartzian | OpenFOAM Installation | 3 | December 12, 2008 13:42 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 15:09 |
