[OpenFOAM.com] OpenFoam installation problem with g++ internal compiler error
Like Tree2Likes
  • 1 Post By bestucan
  • 1 Post By GerhardHolzinger
Old   September 28, 2020, 03:44
Default OpenFoam installation problem with g++ internal compiler error
Ariful Islam Pranto
Pranto is on a distinguished road
During compiling on ubuntu 18.04 with gcc-7, I faced the following error
wmake chemistryModel
g++: internal compiler error: Killed (program cc1plus)
Please submit a full bug report,
with preprocessed source if appropriate.
See <file:///usr/share/doc/gcc-7/README.Bugs> for instructions.
 /home/pranto/Desktop/patrick/enrico_test/enrico/vendor/openfoam/OpenFOAM-dev/wmake/rules/General/transform:25: recipe for target '/home/pranto/Desktop/patrick/enrico_test/enrico/vendor/openfoam/OpenFOAM-dev/platforms/linux64GccDPInt32Opt/src/thermophysicalModels/chemistryModel/chemistrySolver/chemistrySolver/chemistrySolvers.o' failed
make[4]: *** [/home/pranto/Desktop/patrick/enrico_test/enrico/vendor/openfoam/OpenFOAM-dev/platforms/linux64GccDPInt32Opt/src/thermophysicalModels/chemistryModel/chemistrySolver/chemistrySolver/chemistrySolvers.o] Error 4
How can I solve this problem?
Thanks!
Pranto is offline   Reply With Quote
Old   September 28, 2020, 04:18
bestucan's Avatar
Tu Can
bestucan is on a distinguished road
lack of RAM. OpenFOAM after version 8 need a lot of RAM to be compiled. about 8G~16G. add RAM or extend the swap(slow)
njdyck likes this.
bestucan is offline   Reply With Quote
Old   September 28, 2020, 04:25
Ariful Islam Pranto
Thanks @bestucan. Got it.
Old   December 10, 2020, 10:40
Gerhard Holzinger
GerhardHolzinger will become famous soon enoughGerhardHolzinger will become famous soon enough
Thanks!
This issue seems to be resolved with commit 1cd0840. To quote from the commit message:
... reduces the memory requirement for compilation and speed-up parallel
compilation
by the way: the title of the original question mentions "[OpenFOAM.com]", yet the error message contains "OpenFOAM-dev". You are aware that there is a difference?
OpenFOAM-dev as well as the single-digit releases (OpenFOAM-8, OpenFOAM-7, etc.) are from the OpenFOAM Foundation (openfoam.org)
openfoam.com refers to the ESI-OpenCFD release, which are the date-coded releases (OpenFOAM-2006, OpenFOAM-1912, etc.)
njdyck likes this.
GerhardHolzinger is offline   Reply With Quote
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 14:21
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 08:43
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 15:24
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 08:11
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
