[OpenFOAM.org] Error: cannot find qmake either at $QMAKE_PATH or in current $PATH
Like Tree1Likes
  • 1 Post By mahmoodn
Old   July 14, 2020, 12:14
Default Error: cannot find qmake either at $QMAKE_PATH or in current $PATH
Saszalez is on a distinguished road
I have CentOS 7.8.2003 installed. I am trying to compile with Intel compilers, version 18.0.5 20180823. When I run ./makeParaView the following message is printed:
ParaView-5.6.0 exists. Not downloading ...
*** Error: cannot find qmake either at $QMAKE_PATH or in current $PATH
I installed qt5 and its dependencies:
Instalando:
 qt5-qtbase-devel                                x86_64                             5.9.7-2.el7                                  base                             3.9 M
Instalando para las dependencias:
 cups-libs                                       x86_64                             1:1.6.3-43.el7                               base                             358 k
 glx-utils                                       x86_64                             8.3.0-10.el7                                 base                              34 k
 pcre2-utf16                                     x86_64                             10.23-2.el7                                  base                             189 k
 qt5-qtbase                                      x86_64                             5.9.7-2.el7                                  base                             3.3 M
 qt5-qtbase-common                               noarch                             5.9.7-2.el7                                  base                              26 k
 qt5-qtbase-gui                                  x86_64                             5.9.7-2.el7                                  base                             5.2 M
 qt5-rpm-macros                                  noarch                             5.9.7-2.el7                                  base                              27 k
 xcb-util                                        x86_64                             0.4.0-2.el7                                  base                              16 k
 xcb-util-image                                  x86_64                             0.4.0-2.el7                                  base                              15 k
 xcb-util-keysyms                                x86_64                             0.4.0-1.el7                                  base                              10 k
 xcb-util-renderutil                             x86_64                             0.3.9-3.el7                                  base                              12 k
 xcb-util-wm                                     x86_64                             0.4.1-5.el7                                  base                              25 k
I have indicated the path where `qmake-qt5` (/usr /lib64) is installed, but it did not work either.
Saszalez is offline   Reply With Quote
Old   July 16, 2020, 03:29
mahmoodn is on a distinguished road
The actual command is qmake-qt5 but OpenFoam uses "qmake" in scripts. So, a soft link will fix the error.
You have to run the following commands too:
yum install qt5-qtbase-devel.x86_64 cmake3.x86_64 libXt-devel.x86_64 qt5-qtx11extras-devel.x86_64 qt5-qttools-devel.x86_64 qt-devel.x86_64
ln -s /usr/bin/qmake-qt5 /usr/bin/qmake
ln -s /usr/bin/cmake3 /usr/bin/cmake
littleJazz likes this.
mahmoodn is offline   Reply With Quote
Old   July 17, 2020, 07:04
The solution worked perfectly.
Thank you very much.
[OpenFOAM.org] Error: cannot find qmake either at $QMAKE_PATH or in current $PATH achinta OpenFOAM Installation 6 June 8, 2012 18:37
CFX-Pre problem, pls help!!! cth_yao CFX 0 February 17, 2012 01:52
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 13:38
Problem Building OF on Centos cluster (no admin rights) CKH OpenFOAM Installation 5 November 13, 2011 07:32
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
