[OpenFOAM.com] Compile error OpenFoam v1912 on ubuntu 18.04 LTS
Old   June 11, 2020, 00:25
Thumbs down Compile error OpenFoam v1912 on ubuntu 18.04 LTS
Declan Keogh
dkeogh is on a distinguished road
Hi I am having issues compiling openfoam v1912 and I can't find anything similar in previous posts on the forum. When I run ./Allwmake the thirdparty software compiles fine but once it moves to the src directory to compile POSIX the installation fails. I have checked to make sure bashrc is sourced correctly and the directory shortcuts such as $WM_PROJECT_DIR all point to the correct locations. Any help would be appreciated, the log file is attached i had to shorten it to make it fit :/.
dkeogh is offline   Reply With Quote
Old   June 11, 2020, 07:42
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
- Why thumbs down emoji? This software is released aligning the ISO-8601 standard for free. Can't understand such daring complaint.
- Could you please share the steps you have taken for the installation, so that the error can be reproduced? I am almost sure that this is due to some aspect of the local setup, though.
HPE is offline   Reply With Quote
Old   June 11, 2020, 07:59
Declan Keogh
1. Sorry you're right, can I amend it?
2. The files are in my desktop as I'm going to be comparing the results to COMSOL a lot and I didn't want to transfer the data in the command line. I unpacked the files from https://www.openfoam.com/download/install-source.php instead of using the pre-compiled ones. I made sure I followed the steps located here https://www.openfoam.com/documentati...quirements.php. Then i sourced the bashrc file and tested the shortcuts in the ubuntu bash terminal to check that they pointed to where my installation was located. I then proceeded to compiling ThirdParty using ./Allwmake in the ThirdParty folder. When I move to the openfoam folder and run ./Allwmake there it fails when compiling the OSspecific folder.
Old   June 11, 2020, 09:10
Declan Keogh
Okay i've moved it all to the $HOME directory and updated the bashrc files and the dependencies. I've started compiling and the error message i receive is:
wmkdepend: could not open 'wmkdepend: could not open 'Instant.HInstant.H' for source file '' for source file 'signals/sigStopAtWriteNow.Csignals/sigWriteNow.C'': : No such file or directoryNo such file or directory
Old   June 11, 2020, 10:11
Declan Keogh
Okay i've deleted it all, re-downloaded, and it is now compiling fine in $HOME. I would really have liked my installation to be in Desktop but that's okay
[waves2Foam] waves2Foam on an Ubuntu 18.04 with OpenFOAM 1712 JGadelho OpenFOAM Community Contributions 36 April 27, 2024 17:46
[Other] Qt5, OpenFOAM-7 and -v1906, and Ubuntu 18.04 gcengineer OpenFOAM Installation 9 June 22, 2020 19:45
[OpenFOAM.org] Errors in installing OpenFOAM 2.2.2 on Ubuntu 18.04 LTS xixiuqi OpenFOAM Installation 3 December 12, 2019 11:03
[OpenFOAM.org] OpenFOAM 2.40 installation on Ubuntu 12.04 LTS eddykendo OpenFOAM Installation 1 July 18, 2015 18:38
Openfoam Ubuntu 12.04 Unmet dependencies slls33 OpenFOAM Installation 10 April 9, 2013 05:16
