[foam-extend.org] Problem with foam-extend-3.1 |
April 28, 2015, 06:16 |
Rep Power: 12 |
Hi everyone!
I have a similar problem. I did what is written here http://sourceforge.net/p/openfoam-ex...u/Ubuntu_14.04 but I cannot install. When I do ./Allwmake I obtain: Error: Current directory is not $WM_PROJECT_DIR The environment variable are not consistent with the installation. Check the OpenFOAM entries in your dot-files and source them. What can I do? Thank you. |
April 28, 2015, 06:53 |
Rep Power: 12 |
Hi! I have Ubuntu 14.04.2 and I cannot install the foam-extend-3.1.
I did what is written here: https://openfoamwiki.net/index.php/I...oam-extend-3.1 but when I do cd ~/foam/foam-extend-3.1 source etc/bashrc I obtain:bash: /opt/foam-extend-3.1/bin/foamGetSystemInfo: File o directory non esistente bash: /opt/foam-extend-3.1/bin/foamCleanPath: File o directory non esistente bash: /opt/foam-extend-3.1/bin/foamCleanPath: File o directory non esistente bash: /opt/foam-extend-3.1/bin/foamCleanPath: File o directory non esistente bash: /opt/foam-extend-3.1/etc/settings.sh: File o directory non esistente bash: /opt/foam-extend-3.1/etc/aliases.sh: File o directory non esistente bash: /opt/foam-extend-3.1/bin/foamCleanPath: File o directory non esistente bash: /opt/foam-extend-3.1/bin/foamCleanPath: File o directory non esistente bash: /opt/foam-extend-3.1/bin/foamCleanPath: File o directory non esistente It means the file or directory doesn't exists. I have succesfully installed OpenFoam, instead. May you help me? Thanks |
April 29, 2015, 09:36 |
you point on two directories/paths! once you write you type command cd ~/foam/foam-extend-3.1 ->this is in your home directory and the installation should be ~/foam/foam-extend-3.1 the error message points to /opt-directory /opt/foam-extend-3.1... so I guess your ~/.bashrc is not okay it can be okay to install in /opt but ~/.bashrc and other enviroment variables should point on /opt in that case |
April 30, 2015, 04:33 |
Rep Power: 12 |
Thank you for the answer.
Anyway I made a mess and now the error is: Error: Current directory is not $WM_PROJECT_DIR The environment variables are not consistent with the installation. Please source configuration files. Examples: bash: . etc/bashrc tcsh: source etc/cshrc If you sourced the configuration files, please check the 'foamInstall' entry. Eleonora |
April 30, 2015, 13:02 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: http://openfoamwiki.net/index.php/In...with_the_Shell
September 12, 2017, 08:05 |
Problem with foam-extend-3.0
Gabriele Pisetta
Hi all,
I'm experiencing the same problem with the installation of foam-extend-3.0. When I digit Code:
. etc/bashrc Code:
bash: /opt/foam-extend-3.0/bin/foamGetSystemInfo: No such file or directory bash: /opt/foam-extend-3.0/bin/foamCleanPath: No such file or directory bash: /opt/foam-extend-3.0/bin/foamCleanPath: No such file or directory bash: /opt/foam-extend-3.0/bin/foamCleanPath: No such file or directory bash: /opt/foam-extend-3.0/etc/settings.sh: No such file or directory bash: /opt/foam-extend-3.0/etc/aliases.sh: No such file or directory bash: /opt/foam-extend-3.0/bin/foamCleanPath: No such file or directory bash: /opt/foam-extend-3.0/bin/foamCleanPath: No such file or directory bash: /opt/foam-extend-3.0/bin/foamCleanPath: No such file or directory Best regards, Gabriele |
December 31, 2017, 12:34 |
Bruno Santos
Rep Power: 128 |
Quick answer @Pisu: I'm late on this but the solution is that you need to create aliases for each version of OpenFOAM/foam-extend and then start a new terminal.
If it still happens, then it's because there is a lost "etc/bashrc" line that is not within an alias or perhaps you need to log out and then log back in into the desktop (although this shouldn't be necessary). For more details, read section 2.2 "Using aliases to help manage multiple OpenFOAM versions": https://openfoamwiki.net/index.php/I...nFOAM_versions
April 23, 2020, 04:55 |
Foam-extend 4.1
Ndong-Mefane Stephane Boris
Rep Power: 13 |
I have foam-extend 4.1 and openfoam v1906 installed on Ubuntu1804 (Windows subsystem). I'm also using aliases to switch between both environments. the ESI version works without any problem, but when I try to use anything in foam-extend, for example "blockMesh -help", I get the following error: Code:
--> FOAM FATAL ERROR: Could not find mandatory etc entry (mode=ugo) 'controlDict' I saw in a previous post by Wyldckat that this might happen when OF is installed in a directory containing spaces, but it is not the case. the command which foamExec gives: Code:
/opt/foam/foam-extend-4.1/bin/foamExec Thanks in advance for your help, Kazu |
[foam-extend.org] Foam extend 3.1 rpmBuild error. | Saideep | OpenFOAM Installation | 2 | September 25, 2016 20:34 |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 11:51 |
[foam-extend.org] Foam extend 3.1 rpmBuild error. | Saideep | OpenFOAM Installation | 0 | May 9, 2016 15:50 |
fvSchemes in FOAM extend 3.1 | Shenan | OpenFOAM Running, Solving & CFD | 3 | December 22, 2014 10:45 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 14:06 |
