Problems installing OpenFOAM 1.6-ext on Ubuntu 12.04 |
July 16, 2013, 01:37 |
Hi
i tried to install OF-1.6-ext on Ubuntu 12.04. after typing ./Allwmake and after more than 5 hours this message is appeared: make[1]: Target `application' not remade because of errors. what is the problem? thanks. |
July 16, 2013, 17:09 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Arash,
Please try following these instructions: http://openfoamwiki.net/index.php/In...u#Ubuntu_12.04 - namely the section for Ubuntu 12.04. If you still have problems, follow the instructions as given in step #10 and attach the "make.log.tar.gz" file to your next post. Best regards, Bruno
July 17, 2013, 06:42 |
Hi Bruno,
Thanks for your help. I've followed this site: http://repo.or.cz/w/OpenFOAM-1.6-ext....04_64-bit.txt |
July 21, 2013, 06:36 |
Bruno Santos
Rep Power: 128 |
Hi Arash,
the error you got was this one: Code:
g++: internal compiler error: Killed (program cc1plus) Please submit a full bug report, with preprocessed source if appropriate. See <file:///usr/share/doc/gcc-4.6/README.Bugs> for instructions. make[2]: *** [Make/linux64Gcc46DPOpt/decomposePar.o] Error 4
Best regards, Bruno
Openfoam Ubuntu 12.04 Unmet dependencies | slls33 | OpenFOAM Installation | 10 | April 9, 2013 04:16 |
OpenFOAM 1.7.1. using openmpi on Ubuntu 12.04 | dasMopo | OpenFOAM Installation | 5 | February 17, 2013 10:14 |
Installing OpenFOAM 1.6 on ubuntu 9.10 | nabeels | OpenFOAM Installation | 32 | May 10, 2010 03:09 |
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 7 | January 19, 2010 15:39 |
OpenFoam 1.6 Permissions in Ubuntu 9.04 | AlanR | OpenFOAM Installation | 14 | December 28, 2009 19:45 |
