Installation Procedure of OF220 on Ubuntu 10.04LTS
Like Tree8Likes
Old   June 27, 2013, 15:57
Dinesh Balaji
DineshramBalaji is on a distinguished road
Hi Bruno,
these are the results for the commands you gave me to check.
SYSTEMOPENMPI
/usr/lib/openmpi
/usr/bin/mpicc
/usr/bin/mpirun
seems like the file is actually located in bin folder.... just that the bashrc couldn't locate it
DineshramBalaji is offline   Reply With Quote
Old   June 27, 2013, 18:09
Retired Super Moderator
Bruno Santos
Hi Dinesh,
I didn't have a clear enough head in the past few days, but now I've clearly seen the possible problem. Try running this command:
echo $OPAL_PREFIX
If it shows you this path:
/home/bluesim/OpenFOAM/ThirdParty-2.2.0/platforms/linux64Gcc/openmpi-1.6.3/
then it's because you are initializing the OpenFOAM shell environment twice, once with "WM_MPLIB=OPENMPI" and another with "WM_MPLIB=SYSTEMOPENMPI".
If this is the case, then edit the "~/.bashrc" with a text editor and remove the first line that refers to OpenFOAM, as I indicated in the post #18:
Originally Posted by wyldckat View Post
source $HOME/OpenFOAM/OpenFOAM-2.2.0/etc/bashrc
source $HOME/OpenFOAM/OpenFOAM-2.2.0/etc/bashrc WM_NCOMPPROCS=4  WM_MPLIB=SYSTEMOPENMPI foamCompiler=ThirdParty  WM_COMPILER=Gcc46
If you do not know what file I'm referring to, then run this command to see its path:
find ~/.bashrc
Best regards,
Bruno
Old   June 27, 2013, 18:25
Dinesh Balaji
Hi Bruno,
Yeah. there were two references and I commented out the first one. Thanks for the help again.
Old   July 13, 2013, 05:46
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Good morning,
I have tried following the above guide for compiling OpenFoam-2.2.1. It has been successful. For people who already have the 2.2.0 or 2.2.x installed on their machine, the following modification could save a bit of time:
Instead of downloading and compiling all the ThirdParty software, merely do the following in your OpenFOAM-directory for a 2.2.0 version (modify accordingly, if you have 2.2.x.)
ln -s ThirdParty-2.2.0 ThirdParty-2.2.1
This create a symbolic link to the already working ThirdParty compilation, and the compilation of OpenFoam-2.2.1 works smoothly.
Kind regards
Niels
wyldckat likes this.
ngj is offline   Reply With Quote
Openfoam 2.1 installation in ubuntu 12.04 jsm OpenFOAM Installation 11 May 7, 2012 05:56
openFOAM installation in ubuntu 11.10 kirubhakaran OpenFOAM Installation 5 February 17, 2012 03:16
Installation of OpenFOAM-1.6 on Ubuntu 9.10 marval OpenFOAM Installation 2 March 17, 2010 09:33
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 15:25
