how to use paraview-3.14 on OpenSUSE 12.2 with OpenFOAM-2.1.x?
Old   September 26, 2012, 09:12
Default how to use paraview-3.14 on OpenSUSE 12.2 with OpenFOAM-2.1.x?
Pei-Ying Hsieh
phsieh2005 is on a distinguished road
Dear OpenFOAMers,
Is there a way to use Paraview-3.14 with OpenFOAM-2.1.x on OpenSUSE 12.2? I downloaded the binary version, but, whenever I tried to run the binary version on OpenSUSE 12.2 (64 bit), I got "segmentation fault".
Any suggestion?
Pei-Ying
phsieh2005 is offline   Reply With Quote
Old   October 2, 2012, 17:59
Retired Super Moderator
Bruno Santos
Hi Pei-Ying,
I didn't see this thread of yours where you had placed it, namely at the sub-forum for post-processing. I've moved the thread to here to the installation sub-forum.
As for using the pre-built ParaView 3.14.1 in openSUSE 12.2:
  • I've finished testing just now in a virtual machine with openSUSE 12.2 64bit installed in it and followed the instructions I've written here: http://www.cfd-online.com/Forums/blo...-openfoam.html
  • I adjusted the versions accordingly where necessary, so it would use the tarballs for 3.14.1, instead of 3.10.1.
  • As for OpenFOAM itself, the instructions for 2.0 are identical for 2.1 as well.
Since I tested this in a virtual machine, I might not be triggering the segmentation fault you're getting, because in the virtual machine I don't need to use NVidia nor ATI graphics card drivers.
Best regards,
Bruno
PS: I think I've seen a thread of yours on the ParaView mailing list (this one) and I noticed that you haven't specifically mentioned that you were using Qt 4.8.1, which would be the reason why you're getting the errors mentioned on that thread at the mailing list.
Old   October 2, 2012, 19:39
Pei-Ying Hsieh
Hi, Bruno,
Thanks!
I ended up compiling the paraview.3.14.1 from source and used the patch posted by Pablo. OpenSUSE came with QT 4.8.1. I do not know how to downgrade to QT 4.6. But, compiling from source with the patch worked on opensuse 12.2, though.
Apparently the paraview team is aware of the stl ASCII issue. A fix is under review.
But, I still have no clue why I cannot run the paraview development version compiled on opensuse 12.2.
Pei-ying
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
[OpenFOAM] Installation problem with ParaView 3.8.0 on openSUSE 11.2 aero_ ParaView 14 August 2, 2010 19:13
Velocity vector data in OpenFOAM and ParaView mismatch tekky OpenFOAM 9 December 21, 2009 12:26
OpenFOAM 15 with ParaView 340 on OpenSuSE 110 zairja OpenFOAM Installation 7 February 10, 2009 09:31
Paraview problem on OpenSuse gizmo OpenFOAM Installation 13 December 14, 2008 04:09
