[openFuelCell] openFuelCell parallel run failure |
February 28, 2023, 12:35 |
Rep Power: 9 |
I've tried to run openFuelCell in single-core and multi-core. No problems in single-core run, but when launching the multi-core it fails. EDIT: it was a script file problem; now it works. Last edited by Pepino; March 4, 2023 at 04:53. |
April 20, 2023, 12:35 |
Solution
anonymous
Hey Pepino,
can you tell me, what you have changed? |
April 27, 2023, 05:55 |
Rep Power: 9 |
Do you use ubuntu?
With Ubuntu (at least with a "fresh copy" with only csh package installed) the "find" lines in the parprep.csh script file are not working correctly. I did not encounter this with other distro. A super quick test for this problem can be: -parprep_1.csh = first part until "find" commands lines -parprep_2.sh=second part with "find" command lines; notice that this is a bash file -parprep_3.csh=third part with remaining commands -adjust the makefile to run these file with "make parprep" -This "splitting" is also usefull when used to run the files separately to see the file number and pattern inside the folder. This is just to test the problem; clearly more elegant fixes are possible. let me know if it helps. |
April 27, 2023, 06:13 |
#4 | |
Rep Power: 9 |
Clearly, before the creation of this thread, all those steps have been performed (but of course I might have missed some informations)... Last edited by Pepino; April 27, 2023 at 06:18. Reason: grammar |
openfoam, openfuelcell |
Error running simpleFoam in parallel | Yuby | OpenFOAM Running, Solving & CFD | 14 | October 7, 2021 05:38 |
SimpleFoam cannot open include file | Marija | OpenFOAM Running, Solving & CFD | 1 | October 28, 2020 11:35 |
Parallel run: bool ipstream::init attempt to run parallel on 1 processor | SarahLee | OpenFOAM Running, Solving & CFD | 2 | January 11, 2017 04:24 |
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel | JR22 | OpenFOAM Running, Solving & CFD | 2 | April 19, 2013 17:49 |
Parallel Run on dynamically mounted partition | braennstroem | OpenFOAM Running, Solving & CFD | 14 | October 5, 2010 15:43 |
