[swak4Foam] "funkySetFields -time" utilitiy not working
Like Tree6Likes
  • 1 Post By minecraftgp
  • 1 Post By gschaider
  • 2 Post By gschaider
Old   August 12, 2019, 13:45
Default "funkySetFields -time" utilitiy not working
Pu Gong
minecraftgp is on a distinguished road
Hi
I was running a case with tracer injection at a specific time step (10s) in a room with "funkySetFields -time 10". But the tracer still injected at the begining of the modelling (0s). Anyone can help?
Cheers
joshmccraney likes this.
minecraftgp is offline   Reply With Quote
Old   August 12, 2019, 14:17
Pu Gong
My funkySetFieldsDict like this
|  \\    /   O peration     | Version:  plus                                  |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      funkySetFieldsDict;
 expressions
	contaminant1
		field tracer;
		expression "100";
		condition  "set(contaminant1)";
	contaminant2
		field tracer;
		expression "100";
		condition  "set(contaminant2)";
	contaminant3
		field tracer;
		expression "100";
		condition  "set(contaminant3)";
	contaminant4
		field tracer;
		expression "100";
		condition  "set(contaminant4)";
	contaminant5
		field tracer;
		expression "100";
		condition  "set(contaminant5)";
Old   August 12, 2019, 14:21
Pu Gong
And my running log like this, whatever timestep I used, the funkySetFields always starts from 0s
|  \\    /   O peration     | Version:  v1712                                 |
Build  : v1712
Arch   : "LSB;label=32;scalar=64"
Exec   : funkySetFields -time 0.1
Date   : Aug 12 2019
Time   : 17:58:09
Host   : "minecraftgp-HP-EliteDesk-800-G3-TWR"
PID    : 1570
I/O    : uncollated
Case   : /home/minecraftgp/openFoam_case/6.3closedFillingBox/6.3.1singlePlumeTracerPosition/bbpf_sp_bl_t28800
nProcs : 1
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
swakVersion: 0.4.2 (Release date: 2018-12-29)
Create time
Create mesh for time = 0
Time = 0
 Using funkySetFieldsDict
Part: contaminant1
 Modifying field tracer of type volScalarField
 Putting "100" into field tracer at t = "0" if condition "set(contaminant1)" is true
No set contaminant1 at t=0 falling back to 'constant'
 Setting 8 of 103200 cells
 Writing to "tracer"
Old   August 13, 2019, 04:27
Assistant Moderator
Bernhard Gschaider
Build  : v1712
Date   : Aug 12 2019
Time   : 17:58:09
PID    : 1570
I/O    : uncollated
nProcs : 1
Create time
Time = 0
Part: contaminant1
 Writing to "tracer"
You said above that you want to set it at t=10 but your command line option is t=0.1
I'm not quite sure what you want to accomplish. But you've got to be aware: if you set the field at t=10 and the solver starts at t=0 then it will read the t=0 variant and ignore t=10
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   August 13, 2019, 13:38
Pu Gong
Thank you for reply Bernhard, t=0.1 was another attempt but it started from t=0 as well.
I dont think I understand how '-time' utility works. For now I set the startTime=0 in controldict. From my understanding the solver should start at t= 0, and then a new field value will be set (or changed) at t=10 by funkySetFields.
By that do you mean I should set the startTime=10s as well?
Old   August 13, 2019, 18:02
Assistant Moderator
Bernhard Gschaider
FSF is a pure post/preprocessing utility. Which means: you specify a time t=10. It evaluates the expression using the fields it finds in the 10-directory and writes the result there as well
The solver on the other hand reads all it needs to know from the startTime (usually 0) and then runs. It ignores the content of everything else. So whatever is in the 10-directory is ignored (or overwritten)
If you want to "switch on" the tracer at t=10 you'll need a functionObject or a fvOption
joshmccraney and minecraftgp like this.
findCell() in parallel: not working if location is outside the domain TobiWol OpenFOAM 0 January 10, 2018 15:33
Processor 0 not working vishwesh OpenFOAM Running, Solving & CFD 0 November 17, 2017 04:35
ICEM working directory setting Bogesz CFX 2 October 8, 2008 08:45
Help required on working of Micro-oven aero CFX 4 January 19, 2007 09:21
Error: Unable to retrieve mon from working directo Atit Koonsrisuk CFX 6 February 20, 2004 06:07
