[waves2Foam] making prepareCase.sh executable within the bin folder erased all files within?
Old   October 29, 2014, 12:50
Default making prepareCase.sh executable within the bin folder erased all files within?
nikos325
nikos325 is on a distinguished road
Hi guys
I need your help with waves2Foam. I'm new in all these stuff about cfd and linux so made a mistake. After i installed OpenFoam,ParaFoam and waves2Foam i tried to run that tutorials. All went good, i run some easy tutorials with simpleFoam and interFoam and then i moved to waves2foam. after many hours of trying and failing, i manage to run manually (not ./Allrun ) waveFoam solver.when i moved to 3Dwaves tutorials everything went wrong. i tried Allrun command and got the message "make prepareCase.sh executable" (of course i don't know what this mean) but i notice that there was no such file in my bin folder. i searched my computer and find one on another subfolder of waves2foam so i made a copy in my bin folder. then i clicked run in terminal.after a sec everything in my bin folder was deleted (also my trash folder kept empty ) Since then nothing is working.i couldn't run any of the openfoam solvers or open parafoam to review my already solved cases. Plz help!!!!!
nikos325 is offline   Reply With Quote
Old   October 30, 2014, 09:21
nikos325
Any ideas? My next thought is to delete all folders and make a fresh start.
i just need 5-6 hours to compile everything again.
Old   October 30, 2014, 14:29
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Good evening,
@Nikos: It is probably only your waves2Foam that is broken, so simply re-install waves2Foam. It should not take more than 10 minutes.
Kind regards,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
Last edited by wyldckat; October 8, 2018 at 10:46. Reason: removed answer to another post that was on the main thread
ngj is offline   Reply With Quote
Old   November 1, 2014, 06:49
ngj
Good morning Nikos,
I have checked the compilation script (waves2Foam/Allwmake), and it should make the prepareCase.sh file executable per automatic, unless you have some specific permission problems.
Good luck,
Niels
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
OpenFOAM15 paraFoam bug koen OpenFOAM Bugs 19 June 30, 2009 11:46
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
