June 9, 2016, 12:21 |
waves2Foam with plus version?
Kevin Maki
Rep Power: 17 |
Hi All, Any plans to make waves2Foam compatibly with the OpenFOAM-plus version? I see that it compiles well with 3.0.x.
June 9, 2016, 13:28 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi Kevin,
The OpenFoam+ version had slipped my mind. I could consider to try to compile it, however, it will open up Pandora's box for yet another level of cross-version compatibility handling. Consequently, could you come with some arguments for why, support of OpenFoam+ is required? Kind regards, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
June 9, 2016, 16:44 |
Kevin Maki
Rep Power: 17 |
Greetings Niels, and thanks for the reply. Since the plus version is based dominantly on the 3.0 version, I don't expect too much difference for the compatibility with waves2foam. I have done cursory testing in my research group, and we are excited about the LES/DES capabilities in the plus version, as well as the promise for significantly improved scaling of the interFoam-based solvers. If I can get waves2Foam to compile with the plus version, I will do a more serious scaling study with for a ship seakeeping case that is an important benchmark for us. A last argument, the plus version is an important version of the code, and if you can support it, I am sure there will be users that will benefit. I know that we will. Thanks for all that you have done thus far for the marine/ocean/naval community! Kevin
VAWT Sliding Mesh - Negative Torque | Pervispasco | OpenFOAM Running, Solving & CFD | 0 | August 5, 2018 09:59 |
Simplefoam converges to a completely different solution than physical model. | MIchael_P | OpenFOAM Running, Solving & CFD | 5 | July 25, 2018 17:05 |
libz.so.1: no version information available | dmaz | OpenFOAM Running, Solving & CFD | 3 | January 4, 2015 16:54 |
[Matlab] - Add toolbox to version R2012b. | darkluix88 | Lounge | 2 | October 23, 2014 10:23 |
Version 12 speed compared to 11 | maka | OpenFOAM Running, Solving & CFD | 2 | December 21, 2005 05:42 |
