[waves2Foam] Changing the alphaExponent value in the relaxationSchemeSpatial.C file |
September 11, 2016, 10:14 |
ArielJ
Rep Power: 11 |
Hi all,
I want to try changing the alphaExponent value in the relaxationSchemeSpatial.C file and then re-run a simulation with the different value. I went in and changed the value in the code and then tried to compile with wmake and got the following error: Code:
In file included from relaxationZone/relaxationScheme/spatial/relaxationSchemeSpatial.C:27:0: relaxationZone/relaxationScheme/spatial/relaxationSchemeSpatial.H:43:30: fatal error: relaxationScheme.H: No such file or directory compilation terminated. make: *** [Make/linux64GccDPOpt/relaxationSchemeSpatial.o] Error 1 Thanks in advance Ariel |
September 12, 2016, 08:45 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi Ariel,
You should use the ./Allwmake command. It is the only way to make sure that cross version compatibility is handled; no matter how little a change you make. Furthermore, if I understand correctly, what you want, then the shape factor (alpha) is given a default value of 3.5, but you can change it by providing the correct keyword. Please consult the source code, as I do not have access to it at present. Kind regards, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
September 12, 2016, 08:55 |
ArielJ
Rep Power: 11 |
Hi Niels,
Thanks for your quick response. Ok that makes sense then. I should have realised I could just add the alphaExponent value. I'll give this a go and see how I get on. In a related question, I've noticed that the use of relaxation zones seems to affect the free surface elevation further up the domain, resulting in lower free surface elevation than expected. Is this something to do with the implementation of the relaxation zones? Thanks, Ariel |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
