CreatePatch crashes segmentation violation in createPatch for cyclic boundaries |
February 2, 2010, 07:05 |
#21 |
Mattijs Janssens
Rep Power: 26 |
I changed matchTolerance to 1e-3 and it runs fine in 1.6.x. Don't see anything under valgrind either.
p.s. you have illegal patch fields on front and back for 0/p and 0/U. |
February 2, 2010, 13:04 |
#22 |
Vasu
Rep Power: 17 |
Thank you for checking it. I tried running it again with the tolerance 1e-3. And I still get the following errors: bash-3.2$ #0 Foam::error:rintStack(Foam::Ostream&) in "/local/gvasudha/OpenFOAM/gvasudha-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigSegv::sigSegvHandler(int) in "/local/gvasudha/OpenFOAM/gvasudha-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #2 __restore_rt at sigaction.c:0 #3 Foam::tmp<Foam::Field<double> > Foam::fvPatch:atchInternalField<double>(Foam::UL ist<double> const&) const in "/opt/software/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/icoFoam" #4 Foam::fvPatchField<double>:atchInternalField() const in "/opt/software/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/icoFoam" #5 Foam::wedgeFvPatchField<double>::evaluate(Foam::Ps tream::commsTypes) in "/local/gvasudha/OpenFOAM/gvasudha-1.6.x/lib/linux64GccDPOpt/libfiniteVolume.so" #6 Foam::wedgeFvPatchField<double>::wedgeFvPatchField (Foam::fvPatch const&, Foam:imensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/local/gvasudha/OpenFOAM/gvasudha-1.6.x/lib/linux64GccDPOpt/libfiniteVolume.so" #7 Foam::fvPatchField<double>::adddictionaryConstruct orToTable<Foam::wedgeFvPatchField<double> >::New(Foam::fvPatch const&, Foam:imensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/local/gvasudha/OpenFOAM/gvasudha-1.6.x/lib/linux64GccDPOpt/libfiniteVolume.so" #8 Foam::fvPatchField<double>::New(Foam::fvPatch const&, Foam:imensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/software/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/icoFoam" #9 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::GeometricB oundaryField(Foam::fvBoundaryMesh const&, Foam:imensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/opt/software/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/icoFoam" #10 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readField(Foam::Istream&) in "/opt/software/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/icoFoam" #11 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) in "/opt/software/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/icoFoam" #12 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/opt/software/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/icoFoam" #13 __libc_start_main in "/lib64/libc.so.6" #14 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/opt/software/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/icoFoam" I need to know if this might be a problem with installing the new version, since we have changed to 1.6-x recently and I basically cannot understand most of these errors. Sorry if my questions are trivial. But any information would be really appreciated. Best regards, Vasu |
February 2, 2010, 14:19 |
#23 |
Mattijs Janssens
Rep Power: 26 |
Your previous error was from createPatch. This error seems to be from icoFoam and from a wedge patchField. The createPatch case did not contain any wedges.
February 2, 2010, 14:22 |
#24 |
Vasu
Rep Power: 17 |
Yes I'm so sorry, I'm running another case with wedge patch types, and I posted the wrong one. This is the error with the create_patch_test_case: Moving faces from patch front to patch 6 #0 Foam::error:rintStack(Foam::Ostream&) in "/local/gvasudha/OpenFOAM/gvasudha-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigSegv::sigSegvHandler(int) in "/local/gvasudha/OpenFOAM/gvasudha-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #2 __restore_rt at sigaction.c:0 #3 changePatchID(Foam:olyMesh const&, int, int, Foam:olyTopoChange&) in "/opt/software/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/createPatch" #4 main in "/opt/software/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/createPatch" #5 __libc_start_main in "/lib64/libc.so.6" #6 _start in "/opt/software/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/createPatch" Segmentation fault Again I'm really sorry for the mix-up. |
February 3, 2010, 06:04 |
#25 |
Mattijs Janssens
Rep Power: 26 |
Are you using an uptodate 1.6.x?
You could in $FOAM_UTILITIES/mesh/manipulation/createPatch add the debug flags to Make/options (see http://openfoamwiki.net/index.php/HowTo_debugging) and wclean wmake and see where the error comes from. |
February 10, 2010, 11:14 |
similar problems
#26 |
Forrest
Rep Power: 17 |
Hi al,l
I am using OF1.6.x, converted the mesh from ICEM, just two parallel surfaces need to be made cyclic, it worked for one of the mesh I created without any problem. another mesh i made is quite similar with the previous one, but it was just not able to get through when I run the same createPatchDict. The error is something like this ... ---------------------------------------- face 6 area does not match neighbour 5006 by 0.108917% -- possible face ordering problem. patcher_final my area:0.0102764 neighbour area:0.0102876 matching tolerance:0.001 ___________________ Increased the tolerance to 1, cyclic boundary was created but with error messages like this: ------------------------ cyclicPolyPatch:rder : Writing half0 faces to OBJ file "frontBack1_half0_faces.obj" cyclicPolyPatch:rder : Writing half1 faces to OBJ file "frontBack1_half1_faces.obj" cyclicPolyPatch:rder : Dumping currently found cyclic match as lines between corresponding face centres to file "/home/vela/yingchun/OpenFOAM/yingchun-1.6.x/run/lestry03/frontBack1_faceCentres.obj" --> FOAM Serious Error : From function cyclicPolyPatch:rder(const primitivePatch&, labelList&, labelList&) const in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 1547 Patch:frontBack1 : Cannot match vectors to faces on both sides of patch Perhaps your faces do not match? The obj files written contain the current match. Continuing with incorrect face ordering from now on! Dumping frontBack1 half0 faces to "coupled_frontBack1_half0.obj" Dumping frontBack1 half1 faces to "coupled_frontBack1_half1.obj" Dumping cyclic match as lines between face centres to "coupled_frontBack1_match.obj" Synchronising points. On coupled patch frontBack1 separation[0] was (1.37682718046e-07 -5.12042025335e-10 -1.1999999881) On coupled patch frontBack1 forcing uniform separation of 1((-1.85957778909e-06 -2.09167501777e-08 -1.1999999881)) Synchronising points. Points changed by average:8.78905215655e-07 max:0.0143106865778 Removing patches with no faces in them. Removing empty patch frontBack at position 24 Removing patches. Dumping frontBack1 half0 faces to "final_frontBack1_half0.obj" Dumping frontBack1 half1 faces to "final_frontBack1_half1.obj" Dumping cyclic match as lines between face centres to "final_frontBack1_match.obj" Writing repatched mesh to 1e-05 __________________________________ checked the obj mesh with paraview, it seems fine, not sure if this mesh is going to be ok with this error message. Have any of you who had the similar problem found a way to fix this now? Thank you Forrest |
February 10, 2010, 12:41 |
#27 |
Mattijs Janssens
Rep Power: 26 |
Looks like your opposite faces do not have the same area.
What does checkMesh -time 1e-05 say about the resulting mesh? |
[mesh manipulation] CreatePatch | chris1980 | OpenFOAM Meshing & Mesh Conversion | 8 | November 16, 2016 16:44 |
[mesh manipulation] CreatePatch to create cyclic boundary | sbence | OpenFOAM Meshing & Mesh Conversion | 18 | August 30, 2012 07:51 |
[Commercial meshers] CreatePatch for build cyclic patch | make | OpenFOAM Meshing & Mesh Conversion | 7 | January 21, 2009 05:46 |
[mesh manipulation] CreatePatch after subsetMesh | maka | OpenFOAM Meshing & Mesh Conversion | 2 | August 27, 2008 08:28 |
[mesh manipulation] Problem with cyclic patch and createPatch | mattijs | OpenFOAM Meshing & Mesh Conversion | 12 | August 24, 2006 05:57 |
