Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Error in channelOodles tutorial
Old   July 24, 2008, 21:11
Default Hello Hope you're doing fin
  #41
victor
torvic is on a distinguished road
Hello
Hope you're doing fine.
I have a question about "fieldAverage"
I saw its use in the controlDict of oodles, but where can I find the code for the "fieldAverage" function. I checked out "sampling" directory but only found "probes".
I want to take the average of other quantities, say a chemical specie.
Does "fieldAverage" allow for this ?
thanks in advance
Best
V
torvic is offline   Reply With Quote
Old   July 24, 2008, 21:53
Default 1. It's in src/postProcessing.
  #42
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
2. I think so.
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
Old   July 26, 2008, 09:44
Default Well, I know where the problem
  #43
lakeat's Avatar
Daniel WEI (老魏)
Well, I know where the problem is.
According to the numbering of cells, postChannel's channelIndexing.C should have a few modifications.
Best,
Daniel
Daniel WEI
Beijing, China
Email
Old   July 28, 2008, 18:56
Default Hi Daniel sorry for the lat
  #44
victor
Hi Daniel
sorry for the late reply.
you're right, fieldAverage it's already there. I will see how to add the chemical specie field
Thanks so much for your help !
best
V
Old   September 3, 2008, 13:23
Default Hi foamers... I can see
  #45
Nishant
nishant_hull is on a distinguished road
Hi foamers...
I can see that the postChannel utility is not working as the structure of new channelOodles solver has been changed. Now the R field is not being written.
however I want to compare the stress components across the channel and therefore i need the urms and vrms value of the the velocity. ( I took these urms and vrms terms from postchannel utility declaration). How can we obtain these stress values now?
I again have some doubt about the UPrime2Mean. is this UPrime2Mean is stress-components along xx, yy and zz?? If yes, then what about the stress component in XY direction? (which was termed as "uv" in postChannel utility)
your comments plase!
cheers!
Nishant
Thanks and regards,
Nishant
nishant_hull is offline   Reply With Quote
Old   September 3, 2008, 14:21
Default 1. Easy, just copy some lines
  #46
lakeat's Avatar
Daniel WEI (老魏)
1. Easy, just copy some lines from OF-1.4.1
2. Please read the ProgrammerGuide P-16, item "Symmetric rank 2".
Daniel
Daniel WEI
Beijing, China
Email
Old   September 3, 2008, 15:47
Default Thanks Daniel 2) I unders
  #47
Nishant
Thanks Daniel
2) I understand that the 6 components will give me the all stresses and I can see those 6 stresses in the file UPrime2Mean. but How to extract/sample the individual component of the stress from the file UPrime2Mean? I tried sample utility but they do not sample UPrime2Mean field. Doing it in excel is another option but isn't there some available method?
1) Do you mean, I should copy those postchannel-utility files and recompile my openfoam solver? Could you please tell me which files you are referring to?
Thanks once again.
Nishant
Thanks and regards,
Nishant
Old   September 3, 2008, 22:04
Default 1) Compare version 1.4.1 and 1
  #48
lakeat's Avatar
Daniel WEI (老魏)
1) Compare version 1.4.1 and 1.5, note their differences, and you will find a file called calculateAverages.H, try to use it in OF-1.5, and recompile the channeloodles solver.
2) For me, I use postChannel Utility as a template. Note how the utility treat R field and get u'u', u'v', etc., you will know what I mean.
Regards, Daniel
Daniel WEI
Beijing, China
Email
Old   September 4, 2008, 10:39
Default Thanks Daniel Its been grea
  #49
Nishant
Thanks Daniel
Its been great help for me.
I have done some editing in postChannel utility and I have considered UPrime2Mean and R to be same symmmTensor and replaced R with UPrime2Mean and recompiled the utility. Is it a right thing to do?
see the readField.c and collapse.H file
readFields.H
collapse.H
Thanks and regards,
Nishant
Old   September 4, 2008, 10:49
Default Another question is: Is the
  #50
Nishant
Is there any recent modification in channelIndex.C file? I can see that you suggested some modification in that file.
Actually, I am getting some ambiguous result when I compare the results for channel flow using postChannel utility (modified by me) and sample utility available with foam. See the attached picture.. the Umean's x-component is plotted where green line is plotted using postchannel utility and red line is plotted with sample utility.
My channelIndex.C file is as follows:
channelIndex.C
Thanks and regards,
Nishant
Old   September 4, 2008, 13:38
Default Hi Nishant! 1) Compare vers
  #51
lakeat's Avatar
Daniel WEI (老魏)
Hi Nishant!
1) Compare version 1.4.1 and 1.5, note their differences, then you will see what R means
2) Don't use UPrime2Mean, but use R to get what you want.
3) Include "calculateAverages.H" from OF-1.4.1 so that you can get R field.
Cheers,
Daniel
Daniel WEI
Beijing, China
Email
Old   September 4, 2008, 13:54
Default hi Daniel There is define
  #52
Nishant
hi Daniel
There is definetely some problem here. because I have a openfoam-1.4.1 installed on other system and when I plot the Uf with R field then I found that the same difference in Umean's x-component and Uf (which is also umean's x -component defined in postChannel/collapse.H).
What could be the reason for this difference? Why there is different plot for same variable plot? I might be wrong somewhere in my assumption.
Can anybody explain?
Nishant
Thanks and regards,
Nishant
Old   September 4, 2008, 22:32
Default Sorry for my last post, I exam
  #53
lakeat's Avatar
Daniel WEI (老魏)
Sorry for my last post, I examined the case and found (please correct me if I am wrong),
1st, Huh... Don't know how did you get that graph!
2nd, the following are their relationship.
1.4.1 - R field - uniform/nAveragingSteps.raw
1.5 - UPrime2Mean field - uniform/fieldAveragingProperties
R=UPrime2Mean
They are both running average. So you don't nned to copy line from 1.4.1.
Remember everytime you do the reaveraging, don't forget to delete uniform dir.
Daniel
Daniel WEI
Beijing, China
Email
Old   September 5, 2008, 09:36
Default Hi Daniel, Thnaks for repl
  #54
Nishant
Hi Daniel,
Thnaks for reply. Could you please try to compare your Umean.component(0) profile and Uf profile obtained from postchannel utility?? As per the code, they should be the same.
In case you are busy, then could you please send the tar dir of the channel395 case which provides you good Uf profile?
If any one can please see the problem mention on this forum dated September 04, 2008 and give me some suggestion then it would be of great help.
Nishant
Thanks and regards,
Nishant
Old   September 5, 2008, 10:18
Default I got the solution to my probl
  #55
Nishant
I got the solution to my problem.
its here..
http://www.cfd-online.com/OpenFOAM_D...es/1/3532.html
Thanks and regards,
Nishant
Old   September 5, 2008, 12:41
Default Great! http://www.cfd-online.c
  #56
lakeat's Avatar
Daniel WEI (老魏)
Great!
Daniel WEI
Beijing, China
Email
Old   September 29, 2008, 13:44
Default Hi Nishant, Daniel. I wrote
  #57
Mattijs Janssens
mattijs is on a distinguished road
Hi Nishant, Daniel.
I wrote a postChannel that works on any layered and/or decomposed mesh and is simpler to use. Could you test it and let me know if it is correct? The sample dictionary should be self explanatory.
postChannel.tgz
mattijs is offline   Reply With Quote
Old   October 1, 2008, 23:05
Default Thank you, Mattijs, I will try
  #58
lakeat's Avatar
Daniel WEI (老魏)
Thank you, Mattijs, I will try. (I have just returned from my National Day Holiday).
Regards, Daniel
Daniel WEI
Beijing, China
Email
Old   October 7, 2008, 01:25
Default Hi, A nice day to you. I
  #59
lakeat's Avatar
Daniel WEI (老魏)
A nice day to you.
I am thinking how to plot a E(k)-k curve? Could anyone give me some hints?
Is E(k) the same as file "k" in each time directory? I found k value is very small.
And if k=2*pi*f/U, then how can I get f?
The following are k versus 2*Pi/mag(U). I guess it is sgs turbulent energy.
How did you guys do that? In matlab or what?
Thank you.
Ps, the new postChannel works well, thank you Mattijs.
Regards, Daniel
Daniel WEI
Beijing, China
Email
Old   July 16, 2009, 06:30
Marco Turchi
zebu83 is on a distinguished road
Hello everybody!
I download the new postChannel directory and i modify the postChannelDict, but it doesn't work!
old postChannelDict:
Nx 40;
Ny (50);
Nz 30;
new postChannelDict:
Nx 40;
Ny
25
25
Nz 30;
I have to modify anithing else?
thank you
MT
zebu83 is offline   Reply With Quote
Problems with channelOodles tutorial alberto OpenFOAM Running, Solving & CFD 0 June 5, 2007 10:08
ReconstructPar channelOodles error maka OpenFOAM Post-Processing 6 September 13, 2006 17:16
[OpenFOAM] Error while postprocessing channelOodles tutorial in OpenFOAM 13 alberto ParaView 4 April 13, 2006 06:58
Error Tutorial 7 ? Mathew Siemens 2 July 20, 2000 20:35
tutorial error? K.L.Huang Siemens 5 May 1, 2000 14:20
