March 8, 2017, 04:08 |
LES Mesh Scale
Rep Power: 14 |
Hi All
I am doing a simple in-compressible flow (water as medium) inside a twisted pipe/cylinder. Here I am doing an LES computation using CFX and for that I am confused, on what basis I should give my mesh size and time step. And can use Hex mesh or Tetrahedrals ? (Some say Hexamesh is not good for CFD though) The flow inlet is 5 bar and mass flow rate is 10 l/min The geometry is total lenght of 23 mm, Inlet diameter of the pipe is 7mm after 20mm distance the pipe is twisted and a difuser is connected at the end to act like a nozzle. Based on the flow conditions we can say the Reynolds number is around 10000 at the pipe inlet So in this case I am confused how to decide the mesh size (if I should give the minimum mesh size in Ansys mesh which controls the entire mesh or how to proceed) and the time step. Kindly give me some advice please. Thanks |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 10:03 |
LES grid mesh | L3munoz | Main CFD Forum | 0 | April 7, 2010 06:05 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 20:43 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
