Jenna Vergeynst
Rep Power: 10 ![]() |
I have a big mesh generated with snappy. The mesh has different outlets wich operate on different times, so I would like to run cases on parts of the total mesh, depending on which outlet is operating. How can I split a generated mesh? I found the utility 'splitMesh', but it uses faceset, masterpatch and slavepatch and I didn't find explications on those... Thanks! Jenna |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 08:34 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 12:14 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 09:54 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 10:03 |
