pressure b.c. on backward facing step
Old   August 11, 2005, 08:55
Default pressure b.c. on backward facing step
amad
Dear All,
I am dealing with Backward facing step problem. So far what I know from the papers, the boundary conditions which should be applied is only for the velocity, i.e. using no-slip boundary condition. What about for the pressure? can anyone tell me?
Thank you in advance.
Old   August 11, 2005, 09:27
Default Re: pressure b.c. on backward facing step
Tom
The pressure boundary conditions are derived from consis tency with the momentum equations and no-slip conditions. To derive them take the dot product of the Navier-Stokes equations with the normal to your surface and evaluate on the boundary - this gives you an equation for dp/dn which is you boundary condition.
eg. if boundary condition is on y=0 the normal is in the y(=n) direction and you have
dp/dy = nu.d^2u/dy^2 evaluated on y=0
where nu is the viscosity.
Old   August 11, 2005, 09:59
ramp
normal derivative of pressure is equal to zero at all boundaries except outflow where p=0
Old   August 11, 2005, 10:18
Tom
In general it is not zero - if the flow is nonparallel (i.e. it's not a simple pipe flow) then there will be a nontrivial vertical velocity, so that v is not identically zero, evaluating the v-momentum equation on the surface then gives dp/dy = nu.d^2v/dy^2 which is in general nonzero (note I wrote u instead of v in my previous post).
Old   August 11, 2005, 10:53
Amad
what will happen to the profile of velocity, just after the inlet boundary, and just before the outlet boundary? Is there any possibility that the v (NOT u) velocity will be negative or positive instead of zeros?
I tried to simulate on simpler domain. Instead of using domain of backward facing step, I use pipe 2D domain. And what I get is, the profile of the velocity near the inlet boundary, for u is positive, but for v, in the upper part is negative, but in the lower part is positve. And near the outlet boundary, the profile for v is on the other hand, i.e. in the lower part is negative and in the upper part is positve.
Is it really like that???
Old   August 11, 2005, 11:18
Tom
I suspect that this depends upon what your inlet velocity and oulet conditions?
If the inlet velocity is v=0 and u is the fully developed velocity then at the steady state the solution will be every equal to the parabolic profile and v will be identically zero. Any deviation from the fully developed profile will give you a nonzero value of v. Now in this case, when v is nonzero, the noslip conditions on the walls means that you will have, or expect to have, both positive and negative values of v at a single x-location. Far downstream, near the outlet, you would expect the behaviour near the inlet to persist but with smaller vertical velocities - if the pipe is long enough v will be almost zero.
backward facing step flow student Main CFD Forum 6 June 9, 2013 12:17
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
backward facing step problem ian8430 Main CFD Forum 1 January 18, 2011 09:58
Incompressible Navier-Stokes equations for a backward facing step werder85 Main CFD Forum 1 January 3, 2011 17:19
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
