Help: solving unsteady incompressible 3D NS eqns |
April 22, 2005, 07:06 |
my colleages and I (research students) are thinking of solving the unsteady incompressible 3D NS eqns codes to model flapping wings. hence, the boundary'll be moving. we've been looking thru many schemes and we need some opinons... 1. projection or fractional or artificial compress, SIMPLER which is more suitable? we're abit confused. 2. 2nd order crank nicolson or backward euler for time discretization 3. how to move the boundary? what we know is to rotate the whole grids, suggested by liu & kawachi. is there a better solution? 4. we'll be using structured grids. is it better to write ourselves or get a ready program? Is it efficient to generate 2d grids and stacked them together? Sorry for asking so many qns. Anyway, thanks in advance! |
April 23, 2005, 11:35 |
Re: Help: solving unsteady incompressible 3D NS eq
hi, i m a research student and i have written a 2D code for flapping wings. there can be two methods as 1. either use body fitted grids (Lui and Kawachi) 2. or use immersed boundary method.(my recomendation)
there are many disadvantages in using 1st one. structured grid movement is difficult and if u use multiple bodies grid generation is very tricky (go for block grid generator) |
April 23, 2005, 12:52 |
1. SIMPLER algorithm might be slow.
2. 4th order R-K shud be better for time discretisation. 4. Try to use some standard grid generators. Structured grid might be giving some problems near the boundaries -H |
April 23, 2005, 23:03 |
Hi, thanks alot! btw, if SIMPLER is slow, is there a better scheme? what about fractional step/projection or PISO?
Also, will the RK4 be slow since i'm using finite vol? Thanks again |
April 24, 2005, 01:01 |
with RK-$ memory becomes an issue rather than time. Try to look for memory preserving runga kutta schemes.I do not have any idea about projection methods but i would suggest you to read through websites. You can find articles and papers suggesting experience of people with differenct schemes for the specific problem that they had worked on .
-H |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 05:03 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 06:24 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 12:16 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
