February 9, 2005, 18:01 |
k-omega, cross diffusion
I am trying to implement k-omega turbulence model. For free shear (wake), turbulent visciosity is increasing. I have to increase w porduction but how? adding cross diffusion is not enough. Any help will be appreciated.. thanks
February 12, 2005, 07:25 |
Re: k-omega, cross diffusion
It would be preferable to use a mixed model of k-w - k-e type (BSL Model) dd nvs
February 12, 2005, 18:19 |
Thank you very much for responding. I get over the problem by multiplying w production by an artificial constant (between 1-10) that is dependent on the w value and aspect ratio (which affects the diffusion of omega) of the grid cells. But I will definitely start modifying to BSL method. One more general question. How the wake calculations affect the values in the wall boundaries of airfoil? Would the smoothing that I used (made up) affect the solution too much?
February 13, 2005, 10:23 |
Hello, Emre I am very busy, therefore i will answer you a later. But I think that the paper of Balakumar(**) can bring brief replies to you se you soon dd ** : P. Balakumar, Computations of Flow Over a Hump Model Using Higher Order Method With Turbulence Modeling , 43rd AIAA Aerospace Sciences Meeting and Exhibit, Reno, Nevada, AIAA 2005-1270, January 10-13, 2005, pp. 20
February 13, 2005, 17:24 |
Thank you dd. I will search for this paper. see you..
overshooting of Omega in SST komega using simpleFoam | cm_jubayer | OpenFOAM | 2 | June 7, 2020 13:52 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Boundary Conditions for k omega SST | dancfd | OpenFOAM Pre-Processing | 0 | June 10, 2011 00:25 |
implementation of diffusion coefficients and use of diffusion coefficients | stephan | OpenFOAM Running, Solving & CFD | 0 | February 28, 2010 15:30 |
Species diffusion coefficient | iceabc | FLUENT | 1 | June 10, 2004 11:04 |
