Boundary Condition For Pressure vessel Problem
Old   October 21, 2010, 11:55
Post Boundary Condition For Pressure vessel Problem
AC
abhayachougule is on a distinguished road
Hi All,
I am solving a Unsteady CHT problem of pressure vessel , containing gas . Gas is released suddenly from a opening, which causes sudden drop in Temp. .
Now which BC should I give mass flow outlet or pressure outlet(@ 0 gauge pressure) or any other BC? Also is it necessary to specify heat transfer coeff. at outer solid surface, as am not simulating the outer domain?
Thanks in advance.
abhayachougule is offline   Reply With Quote
Old   October 26, 2010, 02:00
Hamid Zoka
Hamidzoka is on a distinguished road
you are about to solve an unsteady problem. according to the fact that outlet gas flow rate varies as the vessel pressure drops, it would be better to set a presure boundary condition at outlet. since we are sure that discharged gas has a constant atmospheric condition.
for the case of outter surface, having not isolated the vessel you should consider heat exchange of vessel with surrounding air as well.
for this purpose you can assume an averaged heat transfer coefficient.
if the vessel is installed outdoor and air blows, forced convection should be considered. an in case the vessel in installed indoor or there is no air blows free convection assumtions shall be considered.
regards
Hamidzoka is offline   Reply With Quote
Old   October 26, 2010, 08:48
AC
Thanking you
asking for Boundary condition in FLUENT Destry FLUENT 0 July 27, 2010 01:55
External Radiation Boundary Condition for Grid Interface CFD XUE FLUENT 0 July 9, 2010 03:53
How to use a solution as an inlet boundary condition in another problem in fluent geryes FLUENT 0 February 25, 2010 17:32
Problem setting boundary condition from file Antonis CFX 1 September 11, 2006 17:53
a problem with Boundary condition M Rad Main CFD Forum 12 November 27, 1998 13:49
