Saving Fluent Surface Monitor Output File
Like Tree1Likes
  • 1 Post By sbaffini
Old   November 10, 2009, 15:29
Default Saving Fluent Surface Monitor Output File
Nicole
fossu15a is on a distinguished road
I am having problems saving and writing to the surface monitor output files (defined in Solve -> Monitors-> surface) when running fluent in parallel. When I am running it on the local machine under 1 node the files are output properly. However when I am running in batch mode it would give the case and data file outputs, which are correct, but the surface monitor files are empty and do not contain any values in them. How can I solve this problem?
Thanks
fossu15a is offline   Reply With Quote
Old   November 12, 2009, 08:10
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
If you properly set the saving of the files than you could check in the Fluent folder (when i run in parallel on windows, fluent does not saves the file in the working folder but in the main one C:\Fluent.Inc\ntbin\ntx86, unless you specify it the whole path and not just the name of the file)
Dronzer likes this.
sbaffini is offline   Reply With Quote
[ICEM] Using Surface Mesh from ANSA for Fluent Sim tommymoose ANSYS Meshing & Geometry 15 March 3, 2016 18:29
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
Fluent File Size John S. FLUENT 2 February 3, 2009 11:20
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 05:59
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 07:43
