April 15, 2003, 23:35 |
Boundary Layer code
Hi, I'm trying to find a boundary layer code using finite-difference or finite-volume method. Could anyone give me a reference to such codes? I'd appreciate it. thank you.
ellen |
April 16, 2003, 06:53 |
Re: Boundary Layer code
If you like Keller-Box in BL then you can have a look the following book. It is using finite-difference. I think some of the source codes are also there.
Momentum transfer in boundary layers -- By Tuncer Cebeci, Peter Bradshaw. Manosh |
April 16, 2003, 08:20 |
The book "MOdeling and Computation and Boundary Layer FLows" by Cebeci contains a floppy with source codes.
April 16, 2003, 13:23 |
Thank you guys. appreciate it.
ellen |
April 21, 2003, 18:11 |
there are a couple of codes that I know of in addition to Cebeci's stuff: 1. GENMIX by Spalding that comes with a book and a fairly good description of the method. 2. EddyBL, or something like that that is distributed with Wilcox's "Turbulence Modeling for CFD" 3. Some very simple codes in the back of Schetz's book "Boundary Layer Analysis". Have fun with them. Regards, BAK_FLOW |
Boundary Layer Question | scottneh | STAR-CCM+ | 3 | September 30, 2010 15:21 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 11:56 |
Boundary Layer Meshing of a nosecone | Chris | FLUENT | 1 | March 15, 2005 13:42 |
Searching for an unsteady boundary layer code | Daniele | Main CFD Forum | 0 | September 20, 2004 09:17 |
New topic on same subject - Flow around race car | Tudor Miron | CFX | 15 | April 2, 2004 07:18 |
