how can i put the computed data into simulation ? |
October 1, 2002, 09:16 |
how cfd software achive simulation ,i mean visualation. do i need using some commercial graphy library such as OpenGL and directx? or shoul i do all of it from basic by myself? thanks in advance.
October 1, 2002, 12:06 |
Re: how can i put the computed data into simulatio
You could use the software (Tecplot). It is very convenient.good luck!
October 2, 2002, 13:35 |
1. Usually commercial packages consist of pre/post-processor and solver. In that case you can use such software.
2. If you have only solver part, there are many visualization tools. Such as tecplot, Matlab, .... But you have to understand the output data type (i.e. structure of the data) Kim. |
October 3, 2002, 03:42 |
what does solver do?
October 3, 2002, 20:39 |
1. Preprocessor: To generate mesh, define boundary conditions, initial conditions.
2. Solver: Solve the system equations. 3. Postprocessor: To visualize flow fields, flow-profiles, etc. Kim. |
Data Center Simulation | scottg | Main CFD Forum | 11 | October 17, 2024 02:22 |
export data at nodes | Meenu | FLUENT | 1 | December 30, 2011 02:24 |
save LES data simulation | ouafa | OpenFOAM Running, Solving & CFD | 0 | January 22, 2010 07:03 |
[OpenFOAM] Saved DATA doesnt have Patch Names | velan | ParaView | 0 | January 9, 2009 08:32 |
Ventilation Simulation & Experiment Data | Luo Shengping | FLUENT | 2 | November 30, 2000 05:00 |
