June 18, 2024, 03:58 |
Hi, guy. I have a qustion about mesh...
eddy
Rep Power: 2 |
https://ibb.co/xLZkSvP
As you can see in this 2D-hexahedral image(Click link), is this mesh a structured mesh or an unstructured mesh? Not all mesh sizes are the same. Thank you for reading my question. Last edited by tjwldhks79; June 18, 2024 at 05:53. |
July 3, 2024, 12:15 |
Praphul T
Rep Power: 12 |
It really depends on how the cells are interconnected. If its 2d, its a quad not a hex. Hexahedron only comes in 3D.
July 4, 2024, 06:03 |
Marcin
Rep Power: 13 |
In CFD (Computational Fluid Dynamics) analysis, a structured mesh is a specific type of mesh generation used to discretize the computational domain. Here's a breakdown of the key characteristics:
Structure: Elements: Structured meshes consist of elements that have a regular, repeating pattern. These elements are typically hexahedrons (3D) or quadrilaterals (2D). Implicit Connectivity: The connectivity between elements is implicit in a structured mesh. This means that the neighboring elements for any given element can be easily identified based on its position in the grid. Imagine a checkerboard pattern – each square "knows" its neighbors based on its location on the board. If U want to learn more about comparision of structured and unstructured - pros , cons - look on the link below https://howtooansys.blogspot.com/202...-analysis.html
Quick Tips and Tricks, Tutorials FLuent/ CFX (CFD) https://howtooansys.blogspot.com/ |
How to perform larger deformations while mantaining good mesh with adjoint solver | FormulaStudentFEB | STAR-CCM+ | 0 | October 13, 2023 11:27 |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
[snappyHexMesh] High quality mesh for wind in complex urban environment | ziboaa | OpenFOAM Meshing & Mesh Conversion | 1 | January 12, 2021 15:33 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
