thomas algorithm
Like Tree2Likes
  • 2 Post By LuckyTran
Old   January 16, 2022, 08:54
Smile thomas algorithm
soufiane002 is on a distinguished road
hello
could we use the Thomas algorithm (TDMA) to solve a tridimensional problem
thank you
soufiane002 is offline   Reply With Quote
Old   January 16, 2022, 10:15
Lucky
TDMA is generally limited to 2D problems, and very simple ones. Very simple 3D problems usually give block-tridiagonal matrices. But the idea of a simplified Gaussian elimination also exists for block-tridiagonal systems. You could also apply operator splitting techniques that yield multiple tridiagonal systems that could be solved sequentially using TDMA. The bigger issue is that it's easy to violate the "tri" part with higher order discretization schemes and/or unstructured grids. TDMA is good for academic learning but for general purpose 3D CFD, you'll be using some kind of sparse solver.
FMDenaro and soufiane002 like this.
Old   January 17, 2022, 08:42
Continuum
Continuum is on a distinguished road
Originally Posted by soufiane002 View Post
hello
thank you
Yes. You can apply an alternating direction implicit (ADI) formation to create a series of 1D problems, each of which can be solved to the Thomas algorithm. It does require a structured mesh though.
Continuum is offline   Reply With Quote
3d resolution, tdma, thomas algorithm
Division by zero error in Thomas algorithm in SIMPLER code execution Dharma Vedula Main CFD Forum 6 July 5, 2017 22:43
Is there an alternative method for TDMA (Thomas algorithm) katakgoreng Main CFD Forum 4 January 19, 2010 07:23
thomas algorithm cvkeshav Main CFD Forum 2 March 29, 2009 06:37
Thomas Algorithm Testing Out of Ideas Main CFD Forum 3 February 8, 2001 23:45
Why Thomas Algorithm for tridiagonal systems? Yogesh Talekar Main CFD Forum 6 July 15, 1999 14:56
