Need help with SimFlow, stuck on splash screen.
Old   February 6, 2021, 07:45
Default Need help with SimFlow, stuck on splash screen.
Arverni is on a distinguished road
I don't really know if this is the correct place to post about this, but I really need help. A Uni course requires me to use SimFlow, and I am encountering problems running it. Installation goes fine, however when I try to launch SimFlow, it gets stuck in the loading screen with the three wave things changing colour, but it never launches.
I have already tried disabling antivirus both during and after installation, updating graphics and Windows, running as admin, making an exception in WIndows firewall, and many more ideas, to no avail. I also installed it on another computer (which I am not going to be able to use), and it runs just fine (even with worse specs). Is there any reason for this? How can it be fixed?
If it is of any use, my specs are GTX 1050 Ti 4GB, 8GB RAM and i5-7400, so apparently I should have no problems running it.
I tried contacting SimFlow support but I am not getting any reply.
Thanks in advance.
Arverni is offline   Reply With Quote
Old   November 20, 2024, 01:04
Kaixin Xu
Lukas Xu is on a distinguished road
Hi! I'm facing the same problem. Did you solved it?
Lukas Xu is offline   Reply With Quote
Old   November 20, 2024, 06:27
Hello, if I recall correctly it had to do with Citrix Workspace and its processes running in the background, which in some way interfered with SimFlow's executable. I solved It by deactivating those processes. Before I found the culprit, what I did was deactivating all non-essential processes, activate them one by one or a small lot and trying to launch SimFlow. The moment I faced the problema I knew which process had to be deactivated at all times. Hope this helps.
Below is a link where I originally posted in reddit and wrote down how I solved It:
https://www.reddit.com/r/CFD/s/8etfq049QL
Old   Today, 02:36
Kaixin Xu
I failed to start the simflow. I guess i should just seek for another CFD software. But thanks for your response.
Modelling Sand Retention Screen - Results Differing from Literature stuey05 FLUENT 0 January 10, 2020 10:49
[Other] SimFlow 2.2 mesh created but not visible MikeHersee OpenFOAM Meshing & Mesh Conversion 3 September 18, 2016 10:29
what "If" condition means in rebound brbbhatti OpenFOAM Programming & Development 0 August 12, 2014 10:18
simFlow release AnetaC OpenFOAM Announcements from Other Sources 7 October 6, 2013 15:41
smoke & screen Marko Main CFD Forum 12 May 15, 2000 12:56
