Hyperbolic or Elliptic Equation
Like Tree1Likes
  • 1 Post By FMDenaro
Old   December 2, 2020, 21:13
Default Hyperbolic or Elliptic Equation
Min Yi
Fishy is on a distinguished road
Is this equation hyperbolic or elliptic?
F=[(∂^2 u)/∂x^2] - u
Fishy is offline   Reply With Quote
Old   December 3, 2020, 04:56
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
First, that appears as a second order ODE, not a PDE. However, you can determine the eigenvalues to determine the mathematical character of the equation.
aerosayan likes this.
FMDenaro is offline   Reply With Quote
Old   December 4, 2020, 01:06
Kira
aero_head is on a distinguished road
The equation you gave us is a second order ordinary differential equations (ODE). From the definition, ODE's contain differentials with respect to only one variable, whereas partial differential equations (PDE's) contain differentials with respect to more than one independent variable.
Other than determining the eigenvalues as stated above from the PDE, you can also tell if it is parabolic or hyperbolic from the characteristics of the flow associated with the equation. For example, diffusion processes are associated with parabolic PDE's.
aero_head is offline   Reply With Quote
Old   December 7, 2020, 15:13
duri
duri is on a distinguished road
Is this 1D version of PDE? If so, then the equation is elliptic, this is Poisson's equation with source term same as solution variable.
Otherwise as mentioned in other replies it is second order ODE. Solution to the problem can be found in text books. In this case there is no elliptic or hyperbolic concept.
duri is offline   Reply With Quote
elliptic function, hyperbolic functions
Solving coupled steady and unsteady equation in OpenFOAM jd87 OpenFOAM Running, Solving & CFD 2 July 22, 2020 12:36
Type of PDE: Hyperbolic or Parabolic or Elliptic? Guo Main CFD Forum 8 August 17, 2018 10:34
Derivation of the Temperature Equation Tobi OpenFOAM Programming & Development 21 April 10, 2018 23:15
Non-linearity Pressure Equation -- PISO algorithm gdeneyer OpenFOAM Programming & Development 1 August 23, 2012 06:19
Elliptic equation UDF dieter FLUENT 1 March 7, 2005 06:28
