NS eq: 3D unsteady compressible to axisymmetric cylindrical 2D laminar+incompressible |
November 17, 2015, 04:44 |
re
Rep Power: 11 |
I've been wracking my brain over this question, can anyone shed some light:
Convert 3 dimensional unsteady compressible NS equations to axisymmetric 2 dimensional incompressible laminar form for a cylindrical pipe.ignore gravity I figured I need to use the cylinderical form of NS equations, which is r, theta and z component. But then I'm lost... |
November 17, 2015, 05:03 |
Filippo Maria Denaro
Rep Power: 73 |
if I am right, a typical set of equations is described in:
J. Fluid Mech., 179, 179-299, 1987 |
November 17, 2015, 05:15 |
re
Rep Power: 11 |
November 17, 2015, 05:39 |
Rep Power: 73 |
many good textbook illustrate the set of equations you want ...
Maybe, you can find them aslo in the wiki page |
November 17, 2015, 05:41 |
Rep Power: 73 |
you can start from here http://ingforum.haninge.kth.se/armin..._STOKES_EQ.pdf
and setting the symmetry constraint |
November 18, 2015, 23:40 |
#6 | |
Michael Prinkey
Rep Power: 25 |
The mass equation will collapse to div U = 0. The energy equation will decouple because there is no density dependence on temperature. The momentum equation will lose the second coefficient of viscosity term because div U = 0. Note that U in the theta direction may be non-zero (swirl velocity), so only d/dtheta terms vanish, not all U_theta terms. |
November 19, 2015, 08:15 |
Rep Power: 73 |
YEs, I agree ... It is also quite common to start from the set of equations in general vectorial expression, setting all hypotheses (constant density, constant temperature, steady flow, etc.) and derive the vector form of the incompressible equation.
Then the vectors and nabla operators can be expressed in the reference system you want to use |
November 28, 2015, 05:53 |
#8 | |
re
Rep Power: 11 |
Modify compressible solver to incompressible | mingzhao | OpenFOAM Running, Solving & CFD | 0 | September 18, 2015 13:50 |
starting compressible flow from incompressible flow results | mihaipruna | OpenFOAM Running, Solving & CFD | 2 | December 3, 2012 11:02 |
convert compressible flow into incompressible flow | Hun Jung | Main CFD Forum | 4 | August 11, 2003 11:10 |
Solving unsteady compressible low speed flow | atit | Main CFD Forum | 8 | July 31, 2000 14:19 |
Compressible vs. Incompressible formulations | Fernando Velasco Hurtado | Main CFD Forum | 3 | January 7, 2000 17:51 |
