October 29, 2008, 21:54 |
Fluent Turbulence model
We have a lab experiment in which we collected temperature data for flow over a heated flat plate. The local Re range from 15,000 - 350,000. Our Fluent model matches up very well with the lower range Re, but at the higher end there is quite a difference. Is there something we should change in the k-epsilon model or maybe change the model type in general as we reach the higher Re?..
thanks |
October 30, 2008, 01:06 |
Re: Fluent Turbulence model
The Reynolds number is a measure of the ratio of inertia forces to viscous forces. It can be used to characterize flow characteristics over a flat plate. Values under 500,000 are classified as Laminar flow where values from 500,000 to 1,000,000 are deemed Turbulent flow. It is important to distinguish between turbulent and non turbulent flow. http://kay.gemba.org/pdf/MAE440/MAE440Exp03.pdf
1- Why are you treating a laminar flow as turbulent? or why are introducing in your calculations something that does not exist (the Reynolds stress)? 2- You mention a heated plate, do you mean isothermal plate, constant heat flux or what? May be you should consider the Rayleigh number as your criteria |
October 30, 2008, 02:44 |
Yes agree, with P2, unless typo, you are laminar
can you post your data for review? |
October 30, 2008, 07:43 |
the problem we are having is that the Re in the square duct is far above 2400. So, we are unsure of the treatment between Turbulent or Laminar..
thanks for the link. |
October 30, 2008, 10:55 |
tis different now. duct flow Re(Dh) = 4*h * u/mu, Re.T ~ 2200 yes. Ok so you are in need of first solving the flow as fully developed, turbulent, no?
October 30, 2008, 11:15 |
the data match problem arises at the higher Res. At the lower Res the Fluent model data matches very well to the lab experiment. But, diverges sharply at the higher Re.
The duct Re >> 2400. The Fluent model is replica of the lab experiment. I am trying to get some suggestions as to why the Fluent model would diverge from the lab data at the higher Res. thanks |
November 18, 2008, 01:11 |
Re: Fluent Turbulence model *NM*
May 31, 2009, 14:34 |
Turbulence at high Re
Helmut Z. Baumert
the k-Eps model is in most cases (there are many different parameter sets on the market) a low-Re closure which fails at solid boundaries in that it predicts a wrong von-Karman constant. There is now a renovated K-Omega model available which rests on a new view of turbulence as a kind of gas of vortex dipoles. It predicts the von-Karman constant as 1/sqrt(2 pi) = 0.399 which is close to the standard value 0.4. I recommend to use the new renovated K-Omega (RENO) at very high Re. For details see chapters 3, 4, 5 in the following book: http://books.google.com/books?id=HVqbdXI29i0C&hl=de Further, a log profile we can expect ONLY for very high Re. At low Re we get the Blasius or Van Veen profile for the velocity. Regards, hzb |
gamma-ReTheta turbulence model for predicting transitional flows | FelixL | OpenFOAM Programming & Development | 123 | August 30, 2022 11:50 |
Fluent 12 k-w SST turbulence model | DarrenC | FLUENT | 0 | December 13, 2009 08:33 |
two turbulence model in fluent | duaiduaihu | FLUENT | 1 | August 26, 2009 19:39 |
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 09:52 |
FLuent CAvitation Model requires Turbulence? | CFDtoy | FLUENT | 2 | January 12, 2007 10:27 |
