Benchmark Results for Thermally driven cavity flow |
June 22, 2015, 15:44 |
Mihir Makwana
Rep Power: 11 |
I am looking for benchmark results ( pressure , velocity and temperature ) to a thermally driven cavity flow , by solving
a) full Navier stokes equations b) Boussinesq approximation I found the following paper : Natural convection in an enclosed vertical air layer with large horizontal temperature differences - By D. R. CHENOWETH AND S. PAOLUCCI. However, I am not able to get the exact values of pressure, velocity and temperature for the example considered in the paper. Can someone provide me with the same. - Mihir |
July 8, 2015, 06:06 |
Mihir Makwana
Rep Power: 11 |
Can someone help me with this ?
Thanks in Advance. - Mihir |
July 8, 2015, 06:16 |
#3 | |
Filippo Maria Denaro
Rep Power: 73 |
I worked on many years ago, in reference you can find some benchmarks, unfortunately the reference list is quite old.... G. de Felice, F. M. Denaro, C. Meola Multidimensional Single Step Vector Upwinded Schemes for Highly Convective Transport Problems. Numerical Heat Transfer, Part B, Vol. 23, 4, Giugno, 1993 |
Review: Reversed flow | CRT | FLUENT | 1 | May 7, 2018 06:36 |
Want Impeller Driven Fluid Flow: What Inlet and Outlet BC to use for Centrifugal Pump | Zev Xavier | FLUENT | 3 | May 9, 2016 07:42 |
Benchmark data for temperature field in 2D cavity flow | Vladislav | Main CFD Forum | 0 | June 18, 2010 13:33 |
target flow rate: varying results | Ryan | FLUENT | 3 | January 9, 2008 14:54 |
on cavity driven flow | yfyap | Main CFD Forum | 3 | September 19, 2001 19:16 |
