June 11, 2008, 04:46 |
high positive linear source term using FEM
Hello!
I have a question about finite element method (FEM) solving Coupled Navier-Stokes equations. The pair of elements I am using is Q2/Q1 for velocity/pressure respectively. I want to solve the velocity vector and the pressure and I have a positive high linear source term, called T*u, where u is the velocity I want to solve. I can solve (both implicity and explicity) the coupled system with FEM without any stabilization when the value of T is not very big. But when T has a big value, I don't get the correct solution. The mesh is really fine, so I don't know if the only solution I have is to use stabilized FEM. If the solution is this one, could you recommend me some article about it. I have something from Huges and Codina. I would be really gratefully if you could give me some help. Thanks in advance and best regards Isi |
Problem of SOURCE term gradient in UDS | wind | Fluent UDF and Scheme Programming | 6 | December 1, 2022 15:21 |
How to define a transient species source term? | aleisia | FLUENT | 3 | March 7, 2011 23:58 |
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 | BlGene | OpenFOAM Meshing & Mesh Conversion | 10 | August 6, 2009 05:26 |
Adding a momentum source term | segersson | OpenFOAM Running, Solving & CFD | 5 | March 3, 2006 00:06 |
UDF Source Term Units? | Brian | FLUENT | 1 | October 24, 2005 10:15 |
