September 28, 2007, 06:50 |
Density condition in Fluent
I am doing a simulation on an inlet geometry of an engine. Ideally in the materials panel i want to set the Ideal Gas condition along with either segregated or coupled solver. The solution is getting diverged with Ideal gas condition,but it does converge with constant Density setting. Is there any specific reason why the solution is diverging with Ideal Gas setting.Also at the higher velocities the segregated solution is getting diverged. |
September 28, 2007, 07:38 |
Re: Density condition in Fluent
try reducing the under relaxation factors.. specially for density
Specifying vertical density gradient in FLUENT | ajagan | FLUENT | 0 | August 18, 2011 23:16 |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 09:23 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 05:41 |
Outflow boundary condition in FLUENT | Sri | FLUENT | 5 | December 5, 2003 05:42 |
Boundary Condition for Fluent 4. | Sanjib Das Sharma | FLUENT | 1 | September 13, 2001 13:34 |
