Hi, I have a C type mesh of a 2D airfoil which i used for my RANS calculations. I have now extruded this profile by a given quantity through the volume>sweep function such that a 3D wing profile now existis. The extruded section of my wing now ends at the wall. Is this sufficinet for 3D DES analysis or should there be a gap between the wall and the wing to capture the effects of downwash?
Does it match your physical geometry? If not then the answer is no, if you want realistic answers. If yes then consider what your grid spacing needs to be to capture the motion scales needed.
Multi-element airfoil analysis | CFD Rookie | Main CFD Forum | 12 | November 17, 2016 07:07 |
Steady level flight airfoil analysis using ANSYS CFX v12 | flutter | CFX | 21 | March 29, 2016 04:51 |
airfoil analysis | Hammam | CFX | 10 | June 22, 2007 14:18 |
Airfoil Mesh for DES Analysis - y+ Value | asd | Main CFD Forum | 1 | May 3, 2007 11:13 |
y+ for Airfoil Analysis | asd | Main CFD Forum | 3 | April 18, 2007 11:54 |
