October 23, 2006, 04:21 |
2D mesh generation!! HELP...!
Hey
I am a construction-engineer student from Denmark, and I have a qustion regarding: "How to make a 2D-simulation of windflow around i.e an airfoile profile??" The problem is how to generate a 2D-mesh. This problem i solved in: Ansys CFX release 10 tutorials (Fluid Structure Interaction and Mesh deformation) about a Valve - it is the generation of such a mesh i would like to do! The way too proceed it NOT by using 3D whit changede Boundery Con. while the length-scale in the 3D-mesh gives problems!! If anyone can help me/tell me (step-by-step??) how to solve this problem i would be very thankfull!! Thanks in advance!! \\Jesper |
October 24, 2006, 18:58 |
Re: 2D mesh generation!! HELP...!
CFX question? Wrong forum. But CFX cannot accept 2D meshes, it is only a 3D solver. So in CFX, you need to make your mesh one element thick. You can make a 2D mesh in Gambit or ICEM if you are running the case in FLUENT.
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 05:24 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM | kawamatt2 | ANSYS Meshing & Geometry | 17 | December 20, 2011 12:45 |
mesh generation for in-cylinder fluent simulation | hennas | ANSYS Meshing & Geometry | 2 | May 31, 2011 16:08 |
General questions on grid-based computing | Adrin Gharakhani | Main CFD Forum | 21 | June 5, 2000 14:47 |
