Temperature (Volume Integral) vs length of the bed Graph
Old   April 23, 2013, 10:20
Default Temperature (Volume Integral) vs length of the bed Graph
Elina Mathew
elina is on a distinguished road
Hi Friends
I want to plot a graph that is temperature distribution along the length of the packed bed for the full simulation...How can I do that..?? I am using Fluent and in that I couldn't give any monitor points for that..Kindly suggest e how to achieve that...??
Its like during charging and discharging process.....I have to plot the graph for Temperature along the bed vs Length of the bed....
elina is offline   Reply With Quote
Old   April 24, 2013, 05:09
michujo is on a distinguished road
Hi, go to Insert/Location/Line. Then you have to specify the initial and final coordinates of the line (straight line) and click apply.
Then go to Insert/Chart. Go to the Data Series tab and select your line as the location. Finally specify what you want to plot in the x and y axis (here it will be the length coordinate and temperature respectively).
Cheers,
Michujo.
michujo is offline   Reply With Quote
Old   April 24, 2013, 08:49
Elina Mathew
Hi Sir
Thanks a lot..I will try that..But for Transient case also we have to use the output file and do the same.. by opening the output file in CFD post...??
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
How to set a constant temperature for entire volume Not only its surfaces fshak92 STAR-CCM+ 7 April 28, 2012 08:21
Packed bed temperature profile João fernandes FLUENT 1 December 25, 2008 06:09
Von Karman Integral Length Scale Txingurri Main CFD Forum 0 May 2, 2002 13:05
