free convection modeling problem
Old   January 30, 2012, 14:37
Default free convection modeling problem
xxx
czaru is on a distinguished road
Hi Fellows,
I am modeling PV panel heated by sun. Between panel and roof there is 5 cm air gap in order to cool it down by natural convection.
please refer to the picture for more information:
I am using solar load model and s2s for radiation between pv and wall (insulation).
Air properties (density: incompressible gas, operating density set in the operating condition: 1.17, air temp set on the pressure inlet 300K)
Operating pressure 101325 Pa
initially I was using laminar model and got results:
then I change for k-e model (enhanced wall treatment, full buoyancy effect) (on pressure inlet I set: 0.001 for turbulence scale and 1% for turbulence intensity):
what do you thing about that?
1. which solution is more probable
2. why we can not observe any air leaving the gap when modeling with turbulence model?
3. do you have any suggestion for this model in general?
Thanks for hepl.
Cesar
czaru is offline   Reply With Quote
Old   February 7, 2012, 09:41
EDRMedeso is on a distinguished road
Hi!
In order to decide whether or not a turbulence model is appropriate for natural convection problems like this one, you should consider the Rayleigh number (Ra). Problems with high Ra call for a turbulence model. As Ra increases rapidly with respect to the characteristic length (Ra ~ L^3), a turbulence model might be necessary for long panel lengths. In that case, you should consider the k-omega SST model with transition.
However, with a pv-panel length equal to 3 m as in the current problem, this becomes a low-Ra problem, and turbulence modelling is neither necessary nor appropriate.
EDRMedeso is offline   Reply With Quote
Old   November 3, 2016, 03:12
Default Which model?
Kenneth
kennethchaw is on a distinguished road
Originally Posted by EDRMedeso View Post
Hi!
Then I wonder if a rectangular box with length of 7m? What is the range of Ra that telling me I should use turbulence model for natural convection problem or not ??
Thanks much!!
kennethchaw is offline   Reply With Quote
Problem in free surface modeling of water-oil mixture scythe FLUENT 4 November 12, 2013 12:47
natural convection problem samantasubho FLUENT 0 October 6, 2010 11:07
Problem with handling LES modeling with dynamic mesh g.akbari OpenFOAM Running, Solving & CFD 0 March 8, 2010 17:18
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 07:47
