Unsteady Fluent simulation
Old   January 24, 2012, 22:45
Default Unsteady Fluent simulation
Aditya
dsn2491 is on a distinguished road
HI,
I am doing shock tube simulations in fluent and would like to know how we can know the actual time(physical time or time in real world) when the simulation is running?
I am new to unsteady simulations so I need some help.
Ansys fluent is being used.
Thanks in advance!!
dsn2491 is offline   Reply With Quote
Old   January 25, 2012, 09:47
Amir's Avatar
Amir
Amir is on a distinguished road
You can be aware of the current time from the residual monitoring window (down-left) or form the console either.
Bests,
Amir
Amir is offline   Reply With Quote
Old   January 25, 2012, 10:50
Default hi
shoeb khan
shk12345 is on a distinguished road
The above way is highly appreciable
alos when you see the vectors or contours you can see the time of the simulation at the left hand down side of the window.
Hope that helps
Shk
shk12345 is offline   Reply With Quote
Old   January 28, 2012, 09:39
Default please go through more details
heidar jafarizadeh
heidar is on a distinguished road
As you know the introduced turbulent models in Fluent conduct the problem to divers results, if you want help please clarify it accordance to the following items:
1- the dimension of your problem
2- 2 or 3 D
3- number of mesh that you used
4- the turbulent method that have been diverged
5- did you used Spallart-Allmaras method please tell me the latest resuduals
6- did you get a convergence around 10-2 for RSM
i am awaited for your short answers
heidar jafarizadeh
heidar.jafarizadeh@gmail.com
heidar is offline   Reply With Quote
Unsteady Simulation - Wierd results from Fluent nikhil FLUENT 3 October 3, 2011 08:13
Time step for unsteady simulation Mohankumarg12 FLUENT 3 July 4, 2011 16:03
Can Fluent start a simulation from a negative time Ted Chu FLUENT 10 November 26, 2008 22:06
problems with unsteady spray simulation Mathias FLUENT 1 July 20, 2006 17:13
About unsteady flow simulation Ji Fidelity CFD 3 June 10, 2003 11:04
