Impact temperature on an aircraft
Old   August 17, 2011, 13:01
Default Impact temperature on an aircraft
Charles
Santos-Dumont is on a distinguished road
I would like to simulate the temperature of the surface of a flying aircraft. The main point of interest is the impact temperature on the leading edges to determine icing datas.
I didn't succeed in modeling it with Fluent. I used different models (Laminar, Spalart Allmart, k-Espilon) with a coupled solver but I get unsatisfying results.
The thing is quite disturbing because after like 20 iterations I get a result that looks pretty good with a higher temperature on the leading edges. But when I iterate more the aircraft surface temperature become constant except for some small hot and randomly located zones.
I activated the viscous heating, and I set the wall and the external temperature at the same value (240 K). The flow speed is 180 m/s and the air density 0.5 kg/m3.
What would you do to solve such a case in terms of model, boundary settings....? There is no tutorial that is about the impact temperature.
Santos-Dumont is offline   Reply With Quote
Old   August 17, 2011, 19:44
Charles
I made some extra tests on a simple cube but I get divergent results after 200 iterations, no matter which solver I chose.
Do somebody have some pieces of advice to share about this viscous heating on a wall ?
Old   August 18, 2011, 13:01
Charles
My test on the cube finally succeed with the Coupled k-epsilon solver.
Still, when I try it on the real geometry, I get the message "Time step reduced for xx cells" after like 200 iterations, and the residuals are diverging a few iterations later...
I read that it's due of sudden changes of temperature between iterations and that it could be caused by wrong solver setup...
Can someone help me out ?
Problem with zeroGradient wall BC for temperature - Total temperature loss cboss OpenFOAM 12 October 1, 2018 07:36
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Bulk temperature Tf is obtained from total or static temperature? NPU_conanxie FLUENT 0 March 30, 2011 06:56
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 01:07
