Boundary Condition For Pressure vessel Problem
Old   October 22, 2010, 04:58
Default Boundary Condition For Pressure vessel Problem
AC
abhayachougule is on a distinguished road
Hi All,
I am solving a Unsteady CHT problem of pressure vessel 1 m dia and 10 m lenght, containing gas at 200+ bar. Vessel is covered with solid material 0.25 mm thickness. Gas is released suddenly from a opening, which causes sudden drop in Temp. from 300 k to -146 k. Mass flow rate @ outlet is 16 kg/s.
Now which BC should I give mass flow outlet or pressure outlet(@ 0 gauge pressure) or any other BC? Also is it necessary to specify heat transfer coeff. at outer solid surface, as am not simulating the outer domain?
Thanks in advance.
abhayachougule is offline   Reply With Quote
inlet velocity boundary condition murali CFX 5 August 3, 2012 09:56
External Radiation Boundary Condition for Grid Interface CFD XUE FLUENT 0 July 9, 2010 03:53
How to use a solution as an inlet boundary condition in another problem in fluent geryes FLUENT 0 February 25, 2010 17:32
Problem setting boundary condition from file Antonis CFX 1 September 11, 2006 17:53
a problem with Boundary condition M Rad Main CFD Forum 12 November 27, 1998 13:49
